since valentines day my scoot hasn't wanted to idle properly and I get P0130 errors (lambda) that sometimes clear themselves and sometimes I have to clear it. and sometimes it stalls.
but it does run well with a little throttle and cruises happily including reaching and holding high speeds on the freeway.
look at this graph of the bike idling on the stand, you can see the rpm rise/fall along with the fuel trim and lambda/o2 as it tries and tries. often this is cycling between 1600 and 2600. sometimes when the rpm drops it goes low enough to stall
crosslinks:
T̶h̶i̶n̶k̶ I've a̶l̶m̶o̶s̶t̶ worn out another throttle body
My new throttle body doesn't rattle. UPDATED: dying 🤬🤬🤬
⚠️ Last edited by SteelBytes on UTC; edited 8 times
