@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
This is an old school Cuppini windshield and I can not get one side off the Vespa ..I believe the end nipple is stuck so far into the part that expands in the handlebar slot. Cant get a hold on the the expanded part enough to unscrew and twist it out. Are the parts in the correct order in the photo?...or is that where i went wrong?
@vespabrian avatar
2022 GTS HPE
@vespabrian avatar
2022 GTS HPE
Loosen the large nut all the way first. This next part is going to sound counter intuitive but it works. Next you use a hammer and tap rather firmly the bracket straight back in the hole. This usually loosens it up and you can then pull the whole thing out. If it doesn't work at first hit it a gain a few times and then maybe try spraying a little WD-40 and try again. I have never not been able to get one out using this method.
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
Yes, that's what I have been trying, got a little scary thinking I would break something..Ill keep at it. Thanks
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
OH!, I do have parts on correctly? Thanks
@vespabrian avatar
2022 GTS HPE
@vespabrian avatar
2022 GTS HPE
JCG my bad I think you may have the parts backwards for a Cuppinin wind shield. It has been a long time since I had one. I am now using a Vespa Screen. I think on yours the cone shaped nut goes up against the large nut. Wait and lets see if anyone else has a Cuppinin shield and can confirm which way is correct.
@vespabrian avatar
2022 GTS HPE
@vespabrian avatar
2022 GTS HPE
I found this article I think you have it right.
http://www.ivespa.com/install-fly-screen-windscreen-vespa-scooter/
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
yep, looks right..thanks
[ Time: 0.0101s ][ Queries: 4 (0.0024s) ][ live ][ 343 ][ ThingOne ]
