ferriswolf wrote:
I cant talk about your actual rear rack, but from things ive stuck on my PXs before, like backrests and top box racks, you use the existing bolts on the tank, unscrew and then these go through the rack holes. One thing you might have to do is change the seat latch post to a taller one due to the change in height of the seat sitting on whatever rack you have put on, this depends on the thickness of the rack mounting plate to the scooter frame.
Thank you for the info. Good to know that I can just unscrew and screw the bolts directly into the tank and not worry about messing with a loose nut or anything. Yeah, I saw from someone else's post that they were having trouble getting the seat to latch when they added the rear rack so I think you might be right and I may end up needing a longer post. I've found a couple online so if it should be a pretty easy fix if is doesn't work with the stock post.
