@greasy125 avatar
@greasy125 avatar
the precursor to "Fuck You Friday"
I'll start it off:
I'd say we can play 20 questions but I'd hazard to say 5 will get you 10 here.
insult to injury was this morning:
Ouch
@orwell84 avatar
@orwell84 avatar
If you didn't have bad luck you'd have no luck at all kind of day...
@az_slynch avatar
@az_slynch avatar
Artisanal Shortbolts, get 'em while they're hot folks.
@greasy125 avatar
@greasy125 avatar
after the front pivot debacle I was all, well lemme go look at this. I knew something was up based on on the size of the bolt heads but I didn't expect that
creative points for using a carb banjo gasket as the new oil plug gasket.
fuckin' farmers...
@maggiegirl avatar
2021 Primavera 150 touring, 2016 LXV 150 ie, 1978 Vespa P125, 2019 Piaggio Liberty 150
@maggiegirl avatar
Rode the new Primavera to work, she's Trinket and there's a reason for that… and got to 'play' awful gopher, or more accurately offal go-for, so I made boxes, labeled boxes, washed metal carts, moved metal carts full of trim to area it goes to, wash carts again, make more boxes, pallet boxes, wash carts, make more boxes, run more carts full to area they go. And the high point was Leaving on my Vespa! And to the shop that does signs to discuss the planned 'girly up my scooter' and yes, I do want that to have Trinket worked into the design, yes, she's a nice gray but I want her to be very loudly My ride and yes, there I go wasting $$ on trinkets again… LOL so, not a bad Thursday but a LOT of exercise
@gickspeed avatar
@gickspeed avatar
Nothing really broke, but. . . 1986 PX150E comes in with terrible running conditions- will not rev out. After a few simple tests figured out it's the stator. Then upon close inspection, some person switched out the 7 wire stator for the earlier double yellow p200e stator. Who does that?! Even if it did run the electrical side would be Fukt.
Also: I think a farmer.
@greasy125 avatar
@greasy125 avatar
right? what the hell is wrong with people?
had fuggin helicoils for not one but TWO 7/16" bolts and you had to cut one off, but you couldn't be bothered to go get the correct shit?
@ray8 avatar
@ray8 avatar
Today:
Got hit in the face by a bird, half helmeted, -- four hours before a new ff helmet arrived.
Tried to remove rear wheel. Two bolts just spun.
Do I win?
JB weld strikes again. Tacks are mine, to remove the first spinning nut.
@whereshaldo avatar
Stella 2T 150, Honda C70
@whereshaldo avatar
The problem is you guys are using your new-fangled combinations wrenches and such. Why? Nothing on this earth you can't fix with a claw hammer.
@greasy125 avatar
@greasy125 avatar
Ray8 wrote:
Today:
Do I win?
ah the old: tire change becomes a whole afternoon ordeal and a parts order!
@ray8 avatar
@ray8 avatar
TGIF:
Replaced all with new harder and longer studs. Viagrafied -- now Nord Locks fit.
New ff helmet fits my fat head. 2XL.
Half helmet riders: Don't watch this until Monday morning at 1am:
https://www.facebook.com/groups/168533503245717/posts/4949059231859763/
@greasy125 avatar
@greasy125 avatar
never forget the cotter pin!
@langolson avatar
Vespa 125 VMA, Vespa SS 180
@langolson avatar
I just gave up about ten minutes ago. The speedo cable was making a squealing sound, so I took the headlight and speedo out to lube up the inner cable. I get it all back together and now it's slipping at the base of the speedo. The fitting at the base of the speedo is worn out. Go figure, squealing is fixed, but now I have to fix the speedo… Tomorrow. Drink in hand.
@subetherbass avatar
The mythical quote of wonder
Pitched.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Thursdays are blurry days, cuz its almost FriYays. I hope all your Thursdays are terribly TERRIFIC.
@greasy125 avatar
@greasy125 avatar
the streak continues.
I should just stay home on Thursdays.
@garncarz avatar
@garncarz avatar
Woodruff key?
@greasy125 avatar
@greasy125 avatar
garncarz wrote:
Woodruff key?
yeah. thankfully it didn't wax the crank. or drop into the case!
the clutch was already trash, but I knew that going in.
the potential for an awful day and me to make a call as the "bad news department" was nigh.
however, the day isn't over yet... and I have one more motor to open...
@orwell84 avatar
@orwell84 avatar
I've had days in the garage that made me feel like I was cursed.
@chandlerman avatar
Innovator
338 Days Since Last Explosion
Innovator
@chandlerman avatar
Assuming it happened Thursday after I got back from running errands, I went out to the workshop this morning and discovered the GL had peed gasoline all over the floor.
Meh.
@killo avatar
I have a few scooters....
@killo avatar
I'd call that a wood-rough key.
garncarz wrote:
Woodruff key?
[ Time: 0.0134s ][ Queries: 4 (0.0055s) ][ live ][ 343 ][ ThingOne ]
