2020 primavera 150
Posts: 423 Location: Lorton virginia |
At what mileage to change hub oil.Manual says I think at 6000 miles if I am reading this right. Dealer told me they change it at first engine oil change.
Posts: 15123 Location: The state of insanity, SoCal |
do it at the first service and then do it each time you change out the rear tire. quick and easy that way and also easy to remember.
Positive
2020 primavera 150
GTS 300ABS, Buddy Kick 125
Posts: 13563 Location: Oregon City, OR |
I had an LX150 for a number of years. Your post made me curious so I went back and looked in the manual for that scooter. It says change at 1000 km (600 mi - i.e. first service), check at each crankcase oil change, and change at 24,000 km (about 15,000 miles). Greasy's simpler approach will obviously do the job.
2020 primavera 150
2020 primavera 150
I looked at the owners manual and it showed to inspect but nothing about changing at any mileage that's why I am confused.It might be a misprint.
Posts: 12008 Location: Hermit Kingdom |
Harry brenner wrote: I looked at the owners manual and it showed to inspect but nothing about changing at any mileage that's why I am confused.It might be a misprint. |
2020 primavera 150
It is confusing to me also.I changed mine at first service interval but will have to look deeper into this .Thanks
change it every tire change, it's cheap insurance and a quart will last you damn near the life of the bike. hell, change it every other tire change. just be sure to change it before things start making noise. because by then, it's too late.
they can leak a considerable amount before making a big mess. some have a vent tube that they'll push out of that leaks to the ground. others will push pas the input seals into the transmission or past the output and onto the wheel-- or for some models into the wheel and all over the brakes. so a check during oil change, and a change during tire change makes everything easy.
Positive
2020 primavera 150
I just changed mine. Very easy job apart from refilling which is a bit fiddly.
There really wasn't a lot in there so I'm glad I took the time to do this. |
