@ray8 avatar
@ray8 avatar
Hey guys,
Tried to change the front tire. Two bolts spun
Took the opportunity to replace all four to fit Nord Locks.
JB Weld disaster. Rage welded the first to get the nut off. Should have removed it first.
New harder, 5mm longer bolts. Ground the heads down and cleaned the zinc plating off to weld em.
Centered and bolted before welding.
Done. Applied hot wax later to prevent rust. Won't compromise brake pads.
Other side
Other side
Room to fit.
Room to fit.
Delicious Nord Lock marks
@ray8 avatar
@ray8 avatar
*rear tire.
@greasy125 avatar
@greasy125 avatar
aces!
looks good!
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Nice proper replacement. melted metal > jbweld. allday erryday
Nice work!!!!
@chandlerman avatar
Innovator
359 Days Since Last Explosion
Innovator
@chandlerman avatar
I'm diggin' it.
I thought those lug nuts went on the other way, though, so the sleeve is protecting the threads from the wheel.
@ray8 avatar
@ray8 avatar
chandlerman wrote:
I'm diggin' it.
They do!
Just trying to show the length added for Nord Locks.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
This is true. On early models, the nut-sleeve threads down between the stud & wheel. On later models, the studs were larger diameter, and the nut is a simple flat nut(no sleeve)
@qascooter avatar
@qascooter avatar
Working on the 62 and 64 Allstates, side by side (engines were VNB2 & VNB5) there were subtle changes, and this is one of them...
@ray8 avatar
@ray8 avatar
Makes sense. At some point in my Allstate's history the front fork was switched out for a later one with a dampener. The photo of the delicious Nord Lock scoring is one of the nuts from the front end.
Btw removing a nut seated to a Nord Lock is a very satisfying feeling. The torque required increases as you remove it.
@sjoerdo avatar
Faro basso 53, Motovespa 58, V50 71
@sjoerdo avatar
great work! I might have to consider doing this. I just placed a spacer on my faro to allow for a 4 inch tyre this makes the bolts come about 5mm short, it fits and it works, but adding 5 mm would give me a bit more confidence...
@psma avatar
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
@psma avatar
Great work! thanks for sharing
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
5mm is a LOT. You should definitely do that.
@sjoerdo avatar
@sjoerdo avatar
Yeah its a lot of wheel and a lot of power the 5mm might be necessary… thanks for showing that it is doable!
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Nice fat rear Sjoerdo! Full pinasco build on that Faro? I've got a VB1 waiting in the rafters to build out as a widebody 8" ripper! One day....
@subetherbass avatar
Don't we all
@geeklion avatar
The Dude
The Dude
@geeklion avatar
SubEtherBASS wrote:
Don't we all
I have way to many scooters on that "one day" list. Wha? emoticon
Or... is it just the right amount. Scooter hoarding is not a crime
@filmworker avatar
1962 VBB1
@filmworker avatar
1962 VBB1
SIP now make 5mm spacers as well as the splined hub holders in early and later styles with longer studs.
https://www.sip-scootershop.com/en/product/spacer-rim-sip_83011000?q=5mm%20spacer
@sjoerdo avatar
@sjoerdo avatar
thanks mate, yes full pinasco: primary, clutch, ignition, cilinder, crankshaft, the works!
got it running recently felt good, nice response, next up is the suspension, still debating wether to keep it old school or to upgrade...
@sjoerdo avatar
@sjoerdo avatar
that is the spacer i have, now i need longer studs on the hub.
@filmworker avatar
1962 VBB1
@filmworker avatar
1962 VBB1
Longer studs are here. 8mm x 21.5. They also sell the studs separately if you want to DIY.
https://www.sip-scootershop.com/en/product/drum-brake-seating-sip-sport-rear_82121000
@ray8 avatar
@ray8 avatar
Follow-up:
Must have nicked the shaft while cleaning the welds. 500 or so miles later got a slight oil leak into the brakes Facepalm emoticon
Lesson learned. Protect the shaft while grinding*!
Dab of epoxy. New seal. Pretty sure I'm good now.
Loving the Nord Locks. Still such a satisfying feeling as the torque increases while removing nuts. Reusable too.
*Insert analogies here.
It's part of a retirement plan. 🥲
[ Time: 0.0107s ][ Queries: 4 (0.0035s) ][ live ][ 343 ][ ThingOne ]
