@jkj-fz6 avatar
BV400, Primavera 150
@jkj-fz6 avatar
I replaced the worn out brake pads on the front wheel of my Zuma. Now the wheel doesn't turn. The caliper is not retracting, I suppose, I've drained any excess brake fluid. Think there's a caliper rebuild in my future?
@wbdvt avatar
@wbdvt avatar
How did it feel when you pushed the pads open prior to replacing?
@jkj-fz6 avatar
@jkj-fz6 avatar
It did seem harder than usual to push back. This is the first time I've replaced pads on this scooter.
@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
Unfortunately the caliper is prone to corrosion and fine grit inside the bore and on the piston due to all the rain , dust and salt thrown up from the road , which will eventually seize it solid , it happened on my LML . I had to buy a new caliper , the piston would'nt move at all . A rebuild definitely beckons . Check the "o" rings on the piston , these may need replacing .
@jkj-fz6 avatar
@jkj-fz6 avatar
Yep, there's a little corrosion on the piston. It seems to clean up, so it might be salvageable if I can find new o-rings.
@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
Is the bore OK ?
@jkj-fz6 avatar
@jkj-fz6 avatar
The bore looks ok. The o-rings look bad. Somewhat puzzling in that the crud and corrosion doesn't look bad enough to prevent the piston from moving. I'll get new seals and try again.
@safis avatar
@safis avatar
How's the brake fluid level?? If it was topped up with worn pads, you're now trying to squeeze a lot more volume in the "tank" by pushing back the caliper pistons…
@jkj-fz6 avatar
@jkj-fz6 avatar
The fluid level's okay. I took some of it out.
[ Time: 0.0109s ][ Queries: 3 (0.0044s) ][ live ][ 343 ][ ThingOne ]
