@garye5007 avatar
GTV 250
@garye5007 avatar
GTV 250
Hi, I have a gtv 250 7500 miles and was planning on replacing sliders and belt. I have had the Dr. Pulley sliders (10g) for about a year uninstalled and just bought a Malossi Kevlar belt and after viewing a lot of posts I am worried that I may have made a mistake. I've seem posts that warn of the Malossi belt riding too high and causing damage... I am perfectly happy with the performance of the scoot stock. This is my first time changing these components and I don't want to hurt anything. Will I be ok doing these upgrades? I have seen some posts about adding a 1mm washer in the variator to make the belt ride lower.. of should I return parts and go back to stock parts?
Advice Please... Thanks in advance
@greasy125 avatar
@greasy125 avatar
you'll be fine on the belt, but those sliders seem bit light unless you're just looking for a jump off the line and riding in stop and go traffic.
when you're in there I'd check the oil pan gasket and trim off any excess just to sure though.
@garye5007 avatar
GTV 250
@garye5007 avatar
GTV 250
thank you for the reply! Do you suggest I get Dr. pulley sliders or get stock? if Dr. pulley what weight do you suggest? Thanks again!
Dr Pulleys will be fine *if* you add that 1mm washer. This one works - add it against the bushing, with the original washer against the driving pulley:
https://scooterpartsco.com/ricambi/021-vespa/washer-disc-between-variator-and-pulley-17x32x1-3mm-for-pia
@fleece avatar
@fleece avatar
converation I had with Maksor about 10.5's albeit they were in an MP3 (but same engine)
Dr Pulley - Have i gone too skinny?
@garye5007 avatar
GTV 250
@garye5007 avatar
GTV 250
Thanks all for the additional replies!
Food for thought!
Gary
[ Time: 0.0085s ][ Queries: 3 (0.0019s) ][ live ][ 343 ][ ThingOne ]
