Hey everyone.
I'm having some pretty bad issues with light path of the headlight illuminating inconsistently on the roadway at night with my Primavera 150. Let me try to explain:
I have the headlight that has the split in the middle, where the upper area illuminates in low beam and then switches to both with the hi-beam.
In the low beam, I see a very distinct bar of light that covers a pretty narrow distance, but goes pretty wide. Almost like a thin rectangle of light. The rest of the illuminated area is pretty dim, mostly from bleeding of the headlight rather than pure illumination. This makes it pretty nerve racking to do turns as my lean means that wide, narrow beam of illumination turns sideways and now I can't see very well what I am actually turning in to.
Anyone have this issue with these kind of LEDs? My bike is only two months old and I'm wondering if it's a common issue with these or if it's clear my install/config is messed up.
Thanks!
