@garncarz avatar
@garncarz avatar
I rebuilt my original rear shock today. Here is a good video from SEA.
Here is the oil seal you will need, $6:
https://www.ebay.com/itm/264203465436
And the top shock buffer:
https://www.scootermercato.com/Scooter-Parts/Buffer/60536
Before: OEM 1964 Piaggio rear shock leaking like a sieve.
This is the seal you will need.
De-rusted and a new coat of paint and all new rubbers.  It's easy to justify being cheap by saying you want to keep it original!
⚠️ Last edited by garncarz on UTC; edited 1 time
@killo avatar
I have a few scooters....
@killo avatar
Nice job. Let us know if it works as expected.
Clap emoticon Clap emoticon Clap emoticon . That's great. I like the idea that you opted not to resort to SIP jank, but kept it original.
@langolson avatar
Vespa 125 VMA, Vespa SS 180
@langolson avatar
You hooked me. I ordered up a seal from your eBay link and am giving the shock rebuild a try. Thanks for the great how-to detail!
parallelogramerist
parallelogramerist
So what did you use for oil?
Here's what I used for my GS shock rebuilds. I did a fair amount of reading saying this is the best, so that's what I got. So far, shocks seem fine with it.
[/img]
@garncarz avatar
@garncarz avatar
I used atf. About SAE15 weight.
Probably fine. I guess as long as it's something with a lower viscosity and won't eat the seals, it's ok.
@garncarz avatar
@garncarz avatar
15w is about as viscous as you want to go. Any thicker and the compression velocity is way too slow. Don't use oil with detergent either. Foam=bad.
@moto64 avatar
@moto64 avatar
How high do you fill the tube ? All the way to the seal so there's no air ?
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
You could use motorcycle fork oil, which is made for the application. You can get various lighter weights, below is an example.
https://www.denniskirk.com
@moto64 avatar
@moto64 avatar
The seal on the rear of the SS has an OD of 32mm and fits differently. Both it and the 20x8x5 seal on the front shock have different types of lips than a normal rotary shaft seal.
The o-ring on the front shock is shot but I think I can match something up.
[ Time: 0.0117s ][ Queries: 4 (0.0050s) ][ live ][ 343 ][ ThingOne ]
