@mopedlar avatar
2001 GTS Super (white), 2021 GTS Super (yellow), 2013 LX 50, 2009 Genuine Stella 2T, 1986 Honda Helix, 1976 Bianchi Snark moped, 1980 General 5 Star moped
@mopedlar avatar
I've changed the oil and filter on my 2021 GTS Super 300 HPE, as well as the final drive oil. The maintenance schedule in my owners manual does not call for a valve clearance check until around 6k miles, but my Vespa dealer says it's one of the tasks that needs to be performed. Do I need it or not? I don't feel confident enough to do the valve clearance check/adjustment myself. It's just too critical a job and I don't want to screw it up. Thanks!
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
The constructor knows the bike the best. So if the users manual says 6k miles, then it is 6k miles.
@wbdvt avatar
@wbdvt avatar
I would follow what the manual says as the maintenance intervals are from the designers and builders of the engine. They probably did a lot of testing to determine maintenance intervals.
So who would know better? The design/build team or the shop mechanic? Not making any slights at shop mechanics.
@mopedlar avatar
@mopedlar avatar
Works for me. Thanks!
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Kind of depends on who's the mechanic and what's the motor?
Scott Fitzgerald is globally recognized as THE guy when it comes to the V-Rod's motor. He had nothing to do with it's development, but continues to keep improving it.
More locally to me, Donny Petersen who recently passed away has written entire books on Harley-Davidson's big twins and is widely respected in the HD community.
I wouldn't just be happy to take either of those mechanic's advice over the manufacturer's, I would feel really lucky to have either of them wrench on my machine.
The thing is, these guys stand out because they're exceptional, and therefore, exceptions... A lot of mechanics are like the office information hoarder, it's hard to really tell how much they do or don't know.
I feel better having my valves checked. It's one of few things I don't bother doing myself.
⚠️ Last edited by adri on UTC; edited 1 time
PX 150 and GTS 300 HPE Super Tech
If your Vespa dealer said a valve check/adjustment is required at the first service, some might suggest that the person who told you this is either (i) misinformed about the vehicles he or she sells, or (ii) dishonest. I am not saying this about your dealer--I am merely pointing out that some might say it.
@maggiegirl avatar
2021 Primavera 150 touring, 2016 LXV 150 ie, 1978 Vespa P125, 2019 Piaggio Liberty 150
@maggiegirl avatar
The reason for that first check at that first approximately 600 miles is to make sure, now that the engine has had some 'break in' that those adjustments are bang on, as that break in might have been enough change that they are not right where they should be, and if there were any flaws in metal that might also show up. That's what the trained crew at MotoEuropa told me with my LXV150IE and they made a very tiny adjustment at that time, and again checked that Liberty and it was right at spec. So, for my $$, I want it done but then I'm female and that's just how I roll.
@kevin_harrell avatar
2018 SYM Wolf 150
2018 SYM Wolf 150
It is not that hard. If you can adjust points, which I am sure you can, you can adjust the valves. There are plenty of videos on the web that can show you how it is done.
@mopedlar avatar
@mopedlar avatar
I know how to do it in theory, it's the execution part I'm afraid of….lol. I'm gonna try to check/adjust the valves on my Honda Navi when the first service is due in 300 miles and see how it goes. I'm not as afraid to try doing it on my Honda Navi as I am on my GTS Super. Thanks for the vote of confidence!
@touring300 avatar
@touring300 avatar
Practice on the Navi, the GTS is more important
nope
@oldschooot avatar
@oldschooot avatar
Just read that a Kymco DT300i owner did his first valve adjustment.....at 65,000 miles.
I'd bet a Vespa can go 6,000 without grenading.
Especially since the owners manual says it can.
O.Z.
@greasy125 avatar
@greasy125 avatar
if it's your own time and your own dime, I'd check them. the HPE's are known to eat oil so what does that say about the rest is kinda my thinking.
fwiw, the two that I've had in for 600's were spot on and another one had both exhaust out at hair at 6K
so, if you wanna spend the dough or you're DIY, check at the 1st for peace of mind. otherwise, do it when you get a belt done and consider it a big service.
just keep oil in it. that's the biggest thing.
[ Time: 0.0133s ][ Queries: 3 (0.0022s) ][ live ][ 343 ][ ThingOne ]
