@boraxman avatar
GTS250
@boraxman avatar
GTS250
Like having a spare and the scooter shops seem to be back ordered or unavailable....Any other plug and play options?
@abner_bjorn avatar
@abner_bjorn avatar
You're talking about the wire from the coil to the spark plug? Check out Scooter West's performance plug wire. It's a bit heavier gauge wire, and a bit longer. I think they make them in house. A very nice unit. https://www.scooterwest.com/modern-vespa/performance/gts-spark-plug-wire-high-perfromance-080341r.html
@boraxman avatar
GTS250
@boraxman avatar
GTS250
Would like to grab one but zero in stock
@25bikez avatar
2007 Kymco People S 250. Helix Hunting.
@25bikez avatar
Make your own. High quality spark plug wire is sold in bulk at most auto parts stores. You can order a cap online and it just screws on to the wire (there's a threaded contact post inside).
@greasy125 avatar
@greasy125 avatar
local motorcycle shop should have what you're after, or if they stock PU/WPS can order what you need.
I can look and see if I've got something for you. might have the scooter west cable on the shelf, otherwise I've got caps and lengths of wire and can custom make something for you.
@boraxman avatar
GTS250
@boraxman avatar
GTS250
Thanks Greasy - Appreciate that. I will get with you a bit down the road, no emergency as I have a fairly new wire at the moment, just like having back-up parts on hand.
[ Time: 0.0080s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
