The seat sensor on my 2008 mp3 no longer detects my butt. Is there a simple fix for this? It doesn't really matter I guess the only issue would be if I left my mp3 tilt lock engaged and engine running and someone twisted the throttle and it fell over.
Basically just want some opinions on if I should do anything to fix this or just let it be.
Edit: I did have some issue with the tilt lock control switch on the right handle. I replaced it with a spare used one I had to make the switch work again. Wondering if this could have any effect as I didn't notice if the seat sensor stopped working after the switch. Changing the switch did make the control work again tho.
Thanks!
