2008 LX 50 & 1978 150 Super
Hello all. I purchased a new VBC muffler from Italy, but it does not fit.
Is the old one incorrect, or is there a different part number that is correct.
See photos below:
@greasy125 avatar
@greasy125 avatar
looks like you got a Friday la liga special!
is it just the bracket or is the whole thing fucky*?
*that's a technical term
@rowdyc avatar
@rowdyc avatar
Those exhausts are for early Supers. 78 supers are 3 ports and require some massaging or a p type of exhaust. May need a longer bolt with a nut.
Throw up a pick of the swingarm where the exhaust screws in.
Thanks for the feedback.
I thought I was loosing my mind. Time to tweek.
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Supers were originally 8 inch bike so the swingarm bracket for a Super pipe is in a different position. A stock Sprint pipe is usually used if the Super has been converted to 10 inch tires and that rusty pipe is Sprint.
My Super is 8"
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
This pleases me.
SoCalGuy wrote:
This pleases me.
cosign
Mystery solved...I think....
The new one did indeed fit after I moved the stand spring to the outboard slot and aligned the muffler properly.
It is on, but the clearance between the tire and the muffler is a little tight. Will it rub when I hit bumps, or did they design it "just right"?
@moto64 avatar
@moto64 avatar
The wheel and the muffler move concurrently with the motor/swing arm unit and the tire should remain in the same position relative to the muffler.
Ah ha, that makes sense.
[ Time: 0.0139s ][ Queries: 4 (0.0064s) ][ live ][ 343 ][ ThingOne ]
