09 piaggio fly 150
09 piaggio fly 150
Advice needed.
I have a 2009 fly 150 with just under 7k on it. I recently did the 190 malossi big bore kit I also have the malossi sport exhaust Kevlar belt ,and rollers. After the big bore i had a shop tune it and change the jets as needed. It ran great for the first ride about 3 hours. Never pulling full throttle. Then to work the next day a 45 min ride but when I was about to go home after work it gave me a bunch of shit starting then started making a clunking noise that sounds like itÂ's from the transmission area. It seemed to smooth out on acceleration but it also now makes a scraping noise before engaging only when I pull out I even feel a slight jolt when it engages. I rode home and babied it but it didnÂ't seem to lose any power although I didnÂ't get on it in fear of braking more. So does this mean new variator? New clutch? I plan to make these upgrades anyway but do I need them now? Also are the dr.pulleys a better choice then malossi rollers? Thanks in advance!
Pull the transmission cover for a looksee.
@greasy125 avatar
@greasy125 avatar
did you do the transmission stuff or did they?
like Z said. pull it and have a look. or if they did the work take that on back!
How old is the belt? If it's the original belt, it might be coming apart.
@greasy125 avatar
@greasy125 avatar
ohhh... wanna wager on it?
I like slices of ham...
dollars to donuts says they didn't get it back together right and the 1/2 pulley is stripped!
09 piaggio fly 150
09 piaggio fly 150
So I should have specified I did the belt and rollers last season with a buddy of mine who's a great mechanic and did the big bore kit last week or so then the tune was done at a reputable shop I asked them the same questions they were taking a while to reply so I was looking for a few different perspectives. I'll take the cover off ASAP and see what's up
09 piaggio fly 150
09 piaggio fly 150
The belt was new a few months ago. I get all my stuff at Scooterpartsco! Just got the 190 kit from y'all
@greasy125 avatar
@greasy125 avatar
When you say "the shop did the tune" what do you mean?
What did they do?
09 piaggio fly 150
09 piaggio fly 150
What did they do?
went thru and made sure the carb was all cleaned and proper and also changed the jets as needed.
As the Greasemeister said, you are going to find something was done incorrectly. Either they left out the washer between the bushing and the outer shaft, or they didn't tighten down the clutch or variator when they put it back together. Is the clutch nut still on?
@greasy125 avatar
@greasy125 avatar
I don't think they touched the driveline from the report of OP.
if they did that's on them.
either way, that's gotta come apart. I want pictures. I want carnage. I demand satisfaction!
@brolsk2 avatar
just a NPS50 (for the moment - lol)
@brolsk2 avatar
so dark...almost educational haha
09 piaggio fly 150
09 piaggio fly 150
So it seems to me after taking the cover off that the backing plate on the clutch is rattling like an sob could this be the source of all the noise? Under acceleration the noise smooths out and gos away. Could that be when the clutch engages? Is a new clutch the answer?
@greasy125 avatar
@greasy125 avatar
the back plates on clutches are known to get loose and rattle.
I'm more interested in the whole: was difficult to start, making a scraping noise, a jolt and clunking noise.
a loose backplate will jingle and jangle at idle but doesn't produce and of those symptoms. it's more annoying than anything but doesn't represent an immediate danger or cause anything like that-- unless it was messed with.
09 piaggio fly 150
09 piaggio fly 150
I'm about to get into it again now I'll update you within an hour or so
[ Time: 0.0109s ][ Queries: 3 (0.0019s) ][ live ][ 343 ][ ThingOne ]
