Thu, 31 Mar 2022 03:26:29 +0000
MP3 400cc 2008
MP3 400cc 2008
Thu, 31 Mar 2022 03:26:29 +0000 quote
Hello everyone,
I'm from Cali LA
Recently purchased Piaggio MP3 2008 400cc. Motorcycle riding perfectly. Today I had a issue for a first time with a tilt lock alarm. When I turn a key, it start alarm if system is on. When I ride and I need to stop and let's say I want to activate tilt lock system, immediately activate alarm ( like you would press the horn in same time). System working and no warning lights, just activate alarm every time when need to be use???
Any advise suggestions will be appreciated
Thu, 31 Mar 2022 06:07:43 +0000
MP3
MP3
Thu, 31 Mar 2022 06:07:43 +0000 quote
It's low on fluid in the roller lock tilt lock in front area. It requires fluid top up.
Mine had same issue. I have one in LA also.
So need to remove the clip on V trim around the Windsceen and swivel it out of way , remove the 5 screw holding the screen on
Remove the black panel and you will see a fluid bottle , top it up
Some say to bleed etc. I never do that.
Then I think you will find after a bit of riding and using system it's fixed and horn alarm gone.
There are many posts with pictures
I just jumped in quickly to comfort you and say it's easy and common
We should go for a ride when I am in Los Angeles in a month or so
Thu, 31 Mar 2022 13:16:30 +0000
MP3 400cc 2008
MP3 400cc 2008
Thu, 31 Mar 2022 13:16:30 +0000 quote
Thank you for advice I will work on it per your recommendation and share outcome.
Thu, 31 Mar 2022 19:39:14 +0000
MP3 400cc 2008
MP3 400cc 2008
Thu, 31 Mar 2022 19:39:14 +0000 quote
Hi,
Is this a reservoir and what kind of fluid ?
DOT4
Thu, 31 Mar 2022 20:19:48 +0000
Thu, 31 Mar 2022 20:19:48 +0000 quote
Yes that is the tilt lock hydraulic system reservoir, and yes you do use dot 4 brake fluid.
Thu, 31 Mar 2022 21:46:23 +0000
MP3
MP3
Thu, 31 Mar 2022 21:46:23 +0000 quote
Was it low level
It's sometimes after topping up takes a day of riding to reinvigorate and self bleed itself. This bottle is the shock absorber lock mechanism , as it locks the front shocks hard , when you apply the roller front tilt.
So need to let it self bleed with use and riding
But that will stop your horn sounding
Mon, 04 Apr 2022 00:07:33 +0000
MP3 400cc 2008
MP3 400cc 2008
Mon, 04 Apr 2022 00:07:33 +0000 quote
Hi all,
Unfortunately it didn't help after riding 40 miles alarm is still on. I did check fluid level it was slightly below and I decided to add more since fluid was Crystal clear. Checked fluid twice after riding, level was great. There is no sign of external leak.
Any further suggestion please fill free to add. I will be more than happy to test it.
Thank you all
Alex
Mon, 04 Apr 2022 00:35:50 +0000
MP3
MP3
Mon, 04 Apr 2022 00:35:50 +0000 quote
Did you activate the switch. As it's the front shock lock. Maybe on off a few times.
Seems wierd it didn't fix it. Especially as it was down a bit. It doesn't need to be down much I found.
Maybe others got a hint.
Mon, 04 Apr 2022 01:39:54 +0000
Mon, 04 Apr 2022 01:39:54 +0000 quote
Is the Alarm a constant beep? which would be fluid level
Or is it a on off beep?
Mon, 04 Apr 2022 02:02:06 +0000
MP3 400cc 2008
MP3 400cc 2008
Mon, 04 Apr 2022 02:02:06 +0000 quote
It is uniform loud sound beep every second four time in a roll.
Tilting system working just fine.
Mon, 04 Apr 2022 02:06:24 +0000
MP3 400cc 2008
MP3 400cc 2008
Mon, 04 Apr 2022 02:06:24 +0000 quote
Mon, 04 Apr 2022 02:12:01 +0000
MP3 400cc 2008
MP3 400cc 2008
Mon, 04 Apr 2022 02:12:01 +0000 quote
Please review my video demonstration for better understanding
Mon, 04 Apr 2022 02:14:37 +0000
Mon, 04 Apr 2022 02:14:37 +0000 quote
You need to bleed the system. It's not hard, just order a 100cc syringe and the proper size tubing. Bleed from the hydraulic solenoid on the shock to the reservoir.
Sat, 09 Apr 2022 12:56:45 +0000
Gilera Fuoco 500ie
Gilera Fuoco 500ie
Sat, 09 Apr 2022 12:56:45 +0000 quote
sensor is bad just disconnect the purple blueish plug in the middle of you fitst picture horn will stop new sensor is about 120 bucks
  DoubleGood Design
[ Time: 0.0288s ][ Queries: 6 (0.0069s) ][ Debug on ][ 283 ][ Thing Two ]
