Vespa 300 ie
Vespa 300 ie
Crying or Very sad emoticon
So I did the Polini big bore kit for the 300gts, ran supremely well..... Checked the oil today, dipstick covered in mayo 😭
I'm an idiot. I don't know where I went wrong.
@billrush avatar
@billrush avatar
That's so sad. After all that work!
Vespa 300 ie
Vespa 300 ie
I'm devastated 😭, do I just give with the scoot? I'm yet to decide.
I would wait until the nausea passes, then study the issue, tidy the shop and breathe.
@billrush avatar
@billrush avatar
Great advice. "We" (the experienced ones" will help you!
What year is your Vespa? Helps to add in your profile. Type year next to model. The " experienced ones" will want to know.
@web-tech avatar
@web-tech avatar
Get the oil that is in there out ASAP. The coolant can damage bearing surfaces.
Get some fresh oil in and run it for a minute.
@outsider avatar
ET 50 GTS250ie Sprint 150
@outsider avatar
Why did you do what you did you have a 300 if not big enough get something bigger.
Probably because people usually buy a Vespa because it's a Vespa and the GTS 300 is the biggest yet many of us wouldn't mind a bit more power (even if it's only a small amount)
@touring300 avatar
@touring300 avatar
Let's just face it, we all like tinkering/modding/tweaking our scoots even if it's just adding stickers, it's part of owning a scooter, sadly and occasionally it can go horribly wrong. Let's hope the OP can come to terms with what has happened and move on.
⚠️ Last edited by Touring300 on UTC; edited 1 time
Vespa 300 ie
Vespa 300 ie
The never ending quest power!
That and I was in an arms race with my dad on his HPE 😂
No tho.... I was talking to a guy with a kit fitted at a meet and he couldn't stop talking about how much it had improved the ride. So I had a few beers 😅 and decided I couldn't like without it.
I have a Hayabusa too, so being fast wasn't my only incentive.
Vespa 300 ie
Vespa 300 ie
I will do this, sound advice.
Is it something as simple as you didnt torque it all down enough. You could get away with new gaskets.
The best bet it to take it apart and see whats going on.
This. Assuming most everything is right , maybe one of those cylinder head bolts was twisted rather than torqued, and did not get tight enough. I have had one snap on me and one twist without snapping. I think that is why, in the scooter west video, Robot double checks the final torque. So, take it apart, inspect, and (if appropriate) order a couple of new gaskets and a set of 4 cylinder head bolts and have another go.
@billrush avatar
@billrush avatar
Matchlessman: What model year is your Scooter(s)? Best if you add it in your profile. Just type the year next to the model name. Cheers!
@billrush avatar
@billrush avatar
Lumpy: What model year is your Scooter? Best if you add it in your profile. Just type the year next to the model name. Cheers!
[ Time: 0.0121s ][ Queries: 3 (0.0018s) ][ live ][ 313 ][ ThingOne ]
