Hi bike broke down ..battery went flat..melted charging relay connecter and fuse dead...got daughter to bring car over to charge battery and think I attached + to - minus side DOH! Blown fuse number 4 or 5( yellow) checked with multimeter 11.7 v...bike starts but tilt lock light on and doesn't rev much ?
Fri Apr 08, 2022 11:50 am
2008 fuoco
Posts: 434 Location: United Kingdom. |
Have you ever checked for the hidden fuse /starter relay under the seat potty for melting as well. Lots of info on here just search for 'hidden fuse' .It's a wonder the bike starts with battery at 11.7v as it's as flat as a fart.
oddjob1 wrote: Hi bike broke down ..battery went flat..melted charging relay connecter and fuse dead...got daughter to bring car over to charge battery and think I attached + to - minus side DOH! Blown fuse number 4 or 5( yellow) checked with multimeter 11.7 v...bike starts but tilt lock light on and doesn't rev much ? |
Fri Apr 08, 2022 11:00 pm
2008 fuoco
Do what i did and make a bigger flap out of rubber sheet to supplement the plastic sheild thats fixed to the underside of the seat potty and encase the relay in a plastic bag it's kept mine dirt free. Best of luck with finding short.
oddjob1 wrote: Yep the underseat one all melted for second time. Gonna see if it can be moved .when I figure out where the other short is |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 40904 Location: Pleasant Hill, CA |
Thu Apr 21, 2022 11:25 pm
2008 fuoco
Thu Apr 21, 2022 11:44 pm
2008 fuoco
Iv'e only been towed once before and that was down the E10 in Belgium ,got a tank slapper where there were road works and all traffic was going down one carriageway and dropped it right infront of two police officers .I think we were told off for towing but as the tower was german and i a brit it was all foreign to us. One wanted to arrest us i think the other dident so we were told to be on our way to ostend to catch the boat.
Fri Apr 22, 2022 4:18 am
Piaggio MP3 300 HPE
Posts: 49 Location: Croydon |
Fri Apr 22, 2022 1:22 pm
2008 fuoco
Raise a complaint with AXA without delay as if your breakdown is with AXA then it's up to them to provide it and not to fob you off and making you do all the work. Compensation should be in the offering for the delay.
oddjob1 wrote: AXA breakdown recovery won't do it and refer me to a company in London who don't answer ..will stick with the main ones next time I renew insurance |
![]() Sun May 08, 2022 7:10 am
Posts: 22045 Location: Harriman, Tennessee, Tn |
![]() Neutrino MP3 492.7 AK, 2013 Moto Guzzi Norge
![]() Sun May 08, 2022 8:48 am
![]() Sun May 08, 2022 8:51 am
oddjob1 wrote: Pretty sure it has seat sensor bypass...so could the resistor have blown ..would this cause tilt lock problem? Or / and check wheel sensors? The most likely thing is that the connection to the resistor (or to the seat sensor if that's still in play) has come undone. Happens all the time when the seat's taken off and put back on again, which is necessary for many maintenance tasks. |
2008 MP3 250ie and 2009 MP3 Sport 500 (Gilera Fuoco)
Posts: 18 Location: WA, USA |
![]() Tue May 10, 2022 4:00 am
