@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
i just bought this model and cosindering some small upgrades. my biggest questioning is what type or what exhausts can be fitted on this scooter with no modifications on the frame. i would be gratefull if there are some pictures also with the exhausts fitted.
thanks in advance
@sjoerdo avatar
Faro basso 53, Motovespa 58, V50 71
@sjoerdo avatar
Congrats, great looking scoot!
Not sure on the US models but in Europe this is a v50 not a special, the specials in Europe have a plastic nosecone and square headlight and are a lot less popular than the v50's (nobody wants a plastic nose).
On my v50 i fitted a banana exhaust (model from the et3) without any mods and it runs great. Every scootershop I know sells them.
@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
Nice original condition . I fitted a Sito+ on mine with no other mods and it certainly improved the performance .
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
its not familiar model if you live in EU. in US its like V50 here in EU. also special 50 is very familiar in Italy. i would like to have a Special with square headlight. i really love em. also this Special cause it has a left battery tray under the side panel unfortunatelly there are not so many options for exhausts!
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
unfortunately i might even go for a pk engine fitted on cause i already have some parts to tune it a little bit such as malossi 136 with reed valve. full circle crankshaft etc etc
@108 avatar
PX 200
@108 avatar
PX 200
I would swap my px200 for a plastic nose 50 special in a heart beat… even a non starting one…
Its such a great scooter
@sjoerdo avatar
@sjoerdo avatar
I've sold these in the Netherlands after complete paint and revision for barely a 1000 euros gone up a little in the past, but still way below the v50's in price.
@108 avatar
PX 200
@108 avatar
PX 200
I'll buy one from you, even a non starter
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
i am also interested
@sjoerdo avatar
@sjoerdo avatar
well then keep an eye on marktplaats.nl the dutch premier buying/selling website
i only have a motovespa for sale and a 50cc italjet dragster at the moment
thanks in advance
Hooray! Looks like our paths will just cross before I leave here, and we'll get a chance meet up tomorrow. Lotsa small frame action here including one old PK50 from Hell and a sweet all original 50S from Heaven we are amateur restoring, including many new parts and a PRO paint job, no rattle cans here except fork and rims, a few motor parts etc.
But I sure hope you can come on your USA 50Special and I can tell you what you like if I know. It's a fairly rare early one w/ the old style steel horncast and round headlite.
The 50S we are working on now as recieved
Lovely one kick motor needed little, mostly just clean up and now ready to drop in.
Yes drop in, we will invert the frame!
Lovely one kick motor needed little, mostly just clean up and now ready to drop in. Yes drop in, we will invert the frame!
~8 hours after arrival
My USA 50 Special
My USA 50 Special
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
It was a pleasure meeting u. I admire the endless thirst u have on learning new things. I really enjoyed the talk. You ve shown and told me lots of things. Just to know it was a big challenge to come there, drive about 15km with my us special cause my top speed is about 40km/h 😱. Insane right? Definitely worth the fuss 😁🥳. So now i am in a search for front headlight. If there is any one that selling one let me know. If i wont find an original i could buy a repro.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
Small treasures found when looking better
Engine button
Engine button
Are there any brake levers that press this button?
@finyoshi avatar
@finyoshi avatar
On my Bajaj there is only a flap of metal with a 90 degree bend attached to the lever with a screw. This tab presses the button when the lever is not pulled.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
Thanks. This is how it originally was? Also does anyone know where i can buy a front headlight with rim?
@finyoshi avatar
@finyoshi avatar
To my knowledge this is how it rolled down the line in India 1995.
Yes, the switch here is wired in parallel with the foot switch and should light up your brake light as is, but with that screw/post screwed in your lever, the switch is off when lever is not pulled. The other swirth on your motor is your neutral lite indicator switch, the footbrake switch is hidden in your foot pedal assembly.
This is not right, only the brake cable should pass thru the tube windows, those wires should run along the side. Also can see it's not the original lever that had the screw post as it doesn't quite fit into that notch. You could drill and tap your lever and add a screw to make it work after you verify your brake lite is ON now after you connect its wires and pushing switch turns it OFF. You can see the switch adjustment to make it work at the right time.
Good luck! I'm still hunting for a headlight rim, can you verify the casting diameter?
I think I found you a headlight rim, also the proper reflector that needs a lens. There are some odd screws needed as well, one screws into the other.
Here's the rim, please confirm your diameter.
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
ur the man! thanks for what ur doin till now!
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
Mattgyver wrote:
i ve seen that but from the picture i dont thing that its the correct one. at least dont look like the one that Voodoo posted above. maybe pictures are not the right ones.
You NEED to get me the headset casting diameter to confirm, and a pic w/ that bodge trim ring removed would help. There should be screw holes at 3, 6 and 9 o'clock.
I found a proper headlight rim and reflector along with the special fasteners you'd need IF yours is 130 mm. You'd need to find a 130mm lens and bulb socket, but that shouldn't be a problem. Please confirm 130mm, and I could bring next trip.
Plating is gone in one place, the rest is nice.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
come on.... isnt this guy a good fella? thanks !
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
well. the special is already at the mechanic. i will restore engine and put a dr 85cc kit on, a 4 disc plates conversion for the clutch, 19/19 carb (still thinking if its worth put a polini reed intake), also for exhaust thinking of putting a sito banana for 50cc or a faco racing. dont know if they fit properly under the side battery tray and also no if they will give some extra power. also i will change primary. i will keep it 3 speed. i think thats all for beggining.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
Headlight
@r_fostoria avatar
'66 Sears Cruisaire Smallframe
@r_fostoria avatar
I'd recommend getting the exhaust with the spring fitting instead of the bolt one. I ordered one of the bolt together ones and the mating flange on the muffler was welded on at such a janky angle, I couldn't even bolt the two part together and had to buy a new exhaust. It's also easier to remove the spring clips.
@markosmarkos avatar
+1 on the spring version. The flange at the bottom of most ET3 replica banana pipes will hit the battery box.
orange circle is where it hits the battery box
parallelogramerist
parallelogramerist
I'd definitely pass on that DR kit. For only a little bit more money you can get the higher quality Pinasco 102 kit...which is what I had on my 50 Special (exact same scooter and color as yours). I also had a Polini pipe and I think (?) a 16 carb on it (it might have been an 19 through). The cruising speed was about 40mph. Top speed down a hill was closer 48mph. At the end of the day the scooter was still way too slow for me so I passed it on to another local scooter enthusiast.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
Didnt expect so quick responses! thank you guys....! ok ill go for the spring pipe!
@finyoshi avatar
@finyoshi avatar
If you rotary valve is good(ish) forget the reed intake.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
well.... for the pinasco i should change the gearing as far as i know. and i am not willing to do that.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
i mean for the 102 kit
parallelogramerist
parallelogramerist
You don't have to change the gearing if you don't want to.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
i think for the 102 kit to work properly you should change gearing
Are you talking about the primary gears or the 3 speed gears? If you're adding power I think you ought to change from the 50cc low primary gears to the stock 90/100cc intermediate primary gears or you'll be winding the piss out of it at any higher speeds. Of course you don't have to.
I do hope your mechanic can sort out your wires and get them out of your throttle tube!
For your proper headlight rim I think we have a winner and I can send it to you soon, watch for PM.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
I was talking about 3speed gears. The primary gears will be changed for sure! Also my mechanic told me to go for the dr90 cause everything is matching good plus change the primary. I wanted to go for the 102 kit which is in the same price but if i got everything my mechanic said right for the 102 kit i have to change primary, change gears, maybe port matching, maybe will need other crankshaft cause the kit is 6port and usually brake shaft bearing? Something like that. Bottomline if i go for the 90 DR kit i would be safer and less cost.
Other opinions would be appreciated
This dude rules. He's like the Mother Teresa for the Vespa needy. He sent me a killer speedometer ring for my GS160 after he noticed my pathetic pitted and corroded one on the hen's tooth another bro (Mercato) sold me at a cool deal. There are lots of coolios here.
parallelogramerist
parallelogramerist
I kept the 3 speed transmission in my engine. I also had the stock crankshaft and did no port matching. The scooter was dead reliable everywhere. I dunno what the brake shaft bearing is. But since you're after other opinions, what about installing a Polini 75 kit? I hear it's better than the Pinasco 102 kit. The bonus is that it's cast iron instead of aluminum and has less ports.
@kourabies avatar
125 TS VNL3
@kourabies avatar
125 TS VNL3
thanks for the reply. i meant break the Shaft bearing... i ll check for the polini 75
[ Time: 0.0406s ][ Queries: 4 (0.0160s) ][ Debug on ][ 313 ][ Thing One ]
