Backlight available in different colours .
![]() Vespa ET4
Posts: 149 Location: Sheffield England |
Sun, 10 Apr 2022 10:48:18 +0000
I did this mod about 5 years ago after I got sick and tired of replacing broken speedo cables on my LML Star every few weeks or so . I had seen the ones that replaced the whole unit , but at that time it completely removed the warning lights as well , which I don't think is a good idea. Therefore I looked for a smaller unit on ebay and found this one which has the advantage of having an internal aerial and a reasonable price . I dismantled and cut out the old speedometer innards so that it just dropped into the speedo case , cut a hole in the lens and sealed it with clear silicone . The wiring is very straightforward , just a live feed as I recall . Ok , it does stick out at the top and is'nt perhaps the prettiest of installations , but it works fine and I still have the warning lights . Probably there are smaller units available now that will fit inside the lens of the unit , which I think would look better , but it ain't broke so I'll stick with what i've got .
![]() Backlight available in different colours . ![]() |
![]() BV350, Primavera 150, Yamaha Zuma 125
Posts: 3820 Location: Twin Cities, Minnesota |
Sun, 10 Apr 2022 11:11:15 +0000
What does the "P05" ("POS"?) mean? Do you still have an odometer/trip meter?
![]() Vespa ET4
Sun, 10 Apr 2022 16:41:06 +0000
POS is displayed when it has'nt picked up a satellite . In this case it can't because it is in the garage.
![]() Vespa ET4
Sun, 10 Apr 2022 16:46:50 +0000
Sorry , I forgot to add that it has odometer and trip function options and a couple of others that I have'nt bothered with.
![]() Sun, 10 Apr 2022 23:38:52 +0000
2019 Supertech EURO3 41,000km
Posts: 2755 Location: Batmania aka Melbourne, Australia |
![]() 2019 Supertech EURO3 41,000km
I hope its more accurate and less laggy than the GPS in phones
![]() Vespa ET4
![]() Mon, 11 Jul 2022 19:04:42 +0000
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Posts: 7119 Location: Nashville |
Lucky
![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
I thought I was the only one that did this!
I have 52mm GPS speedo's similar to yours in both my 1962 VBB and 1962 GL. I need to finish routing the antenna wire and install a proper backplate, but they both work great. The antenna is externally mounted to the mirror stalk. I fabricated a small mounting plate for it. ![]() GL ![]() VBB |
![]() Vespa ET4
Fri, 26 Aug 2022 04:14:28 +0000
Sorry about the late reply , I have'nt been on the site for a couple of months . Looks a neat installation .
![]() '81 Special, '81 P150X, '87 PK50 Nuova '13 LML Star 200
Posts: 312 Location: Ukraine. Kyiv. |
![]() Vespa ET4
![]() Fri, 25 Nov 2022 19:50:03 +0000
P Series / Li / LML / Motobi
Posts: 510 Location: UK - 3rd Rock From the Sun |
![]() P Series / Li / LML / Motobi
Could i have a link to this please?
Actually could everyone who posted that they do the "GPS thang" post there links too?? id like to see if i can modify my Mk1 T5 with dead as a door nail speedo and rev counter to use this approach - there is plenty of space in the headset to accomodate JOHNTEE wrote: I did this mod about 5 years ago after I got sick and tired of replacing broken speedo cables on my LML Star every few weeks or so . I had seen the ones that replaced the whole unit , but at that time it completely removed the warning lights as well , which I don't think is a good idea. Therefore I looked for a smaller unit on ebay and found this one which has the advantage of having an internal aerial and a reasonable price . I dismantled and cut out the old speedometer innards so that it just dropped into the speedo case , cut a hole in the lens and sealed it with clear silicone . The wiring is very straightforward , just a live feed as I recall . Ok , it does stick out at the top and is'nt perhaps the prettiest of installations , but it works fine and I still have the warning lights . Probably there are smaller units available now that will fit inside the lens of the unit , which I think would look better , but it ain't broke so I'll stick with what i've got . |
Mon, 28 Nov 2022 18:24:42 +0000
roland87 wrote: XOSS G from Aliexpress $19.90 You need the most cheap version G not G+ as the last one have functions that useless for scooter. |
