Thu Apr 14, 2022 8:12 am
Piaggio MP3 400
Piaggio MP3 400
Thu Apr 14, 2022 8:12 am linkquote
Braking starting… (MP3_500_2017)
when I am trying to start the MP, the starter start running than stop after 2 secund, this happened repetitively like the ECU prevent the engine running.
ABS & ASR light blinking
Any idea?
Fri Apr 15, 2022 6:00 am
2015 MP3 500 ie Business
Fri Apr 15, 2022 6:00 am linkquote
ABS & ASR are supposed to be blinking until the engine has exceeded something like 10km/h IIRC
Sounds like your issue is with a component inside the immobilizer system
Fri Apr 15, 2022 7:33 am
Piaggio MP3 400
Piaggio MP3 400
Fri Apr 15, 2022 7:33 am linkquote
I just needed this information regarding the ASS/ASR because I never raid on this bike since I ust buy it with the failure.
Finally, after 5 hours of investigation I found the problem.
the failure is the "speed motor sensor"
Locate in the engine case just near the stator generator.
Sat Apr 16, 2022 10:19 am
50cc Beo, BigBeo 2003
Sat Apr 16, 2022 10:19 am linkquote
Also known as crankshaft position sensor, CPS.
Sat Apr 16, 2022 3:28 pm
2018 Mp3 500 LT Sport ABS
Sat Apr 16, 2022 3:28 pm linkquote
Well done Azencot Nir on finding your fault,Its always good when you solve a problem.
  DoubleGood Vespa Design
[ Time: 0.0305s ][ Queries: 5 (0.0097s) ][ Debug on ][ 211 ][ Thing One ]
