Sat, 23 Apr 2022 01:49:04 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sat, 23 Apr 2022 01:49:04 +0000 quote
Hi everyone.
Long story short - my mate gave me a Vespa ET2 50cc. His mate gave it to him as there's was something wrong with it. He decided he didn't have the time, so gave it to me.
I know nothing about scooters or 2-strokes. I'm pretty handy with the tools working on cars though.
So, when I got it I managed to get it started, but it wouldn't rev cleanly. Then it stopped dead very abruptly. And wouldn't kick over any more.
I've pulled the drive cover and there is definitely a spot where it jams tight. Using a socket, I can turn it over but it get stuck hard at the same spot every time. I can then turn the engine backwards slightly and it will then get past the binding spot but it's still super tight. The rest of the revolution is nice and smooth.
I've pulled the plug which makes no difference in how it turns over.
It's been pulled apart before as some of the screws for the plastics are missing etc. There's some silastic on the rubber adaptor between the carb and engine, which was hiding some cracks, so I'll get a new one of them when I get around to ordering parts.
I figure I'm at the point of no return as I'm about to pull the head and barrel to see what it looks like as I have no idea what to do next.
Any help appreciated. Always enjoy learning new things.
Sat, 23 Apr 2022 02:03:22 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sat, 23 Apr 2022 02:03:22 +0000 quote
I initially thought I needed to remove the whole engine and swingarm, but it looks like I can pull the head with the engine in place.
Sat, 23 Apr 2022 02:37:36 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sat, 23 Apr 2022 02:37:36 +0000 quote
Ok, head and barrel off. Engine still doesn't like turning over. It seems the bearing between the rod and the crank is seizing.
Is this now an engine out job?
Sat, 23 Apr 2022 03:01:29 +0000
ET 50 GTI250 ET150 Pearl White ET 150 Colbalt Blue
Sat, 23 Apr 2022 03:01:29 +0000 quote
I feel sorry for you. It is a problem when you have no oil the oil pump belt may have broke you should have tried mixing some two stroke oil in the gas and it may have firerd Good luck just a guess on my part. and I know nothing.
Sat, 23 Apr 2022 03:56:43 +0000
73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 90 V5N 50, 01 ET2, 2015 HD Road Glide Special
Sat, 23 Apr 2022 03:56:43 +0000 quote
Ouch! If the connecting rod and big end bearing aren't spinning freely it's toast. Yes full open up job. You'll want to replace bearings and seals while you're in there.
Sat, 23 Apr 2022 04:01:26 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sat, 23 Apr 2022 04:01:26 +0000 quote
Yeah, lack of oil is likely a contributor. What mix ratio do they need?
Does anyone have a link to a pdf repair manual? I'm working blind so far.
Sat, 23 Apr 2022 04:23:50 +0000
Sat, 23 Apr 2022 04:23:50 +0000 quote
https://manuals.wotmeworry.org.uk/Vespa/ET2/
Sat, 23 Apr 2022 05:51:32 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sat, 23 Apr 2022 05:51:32 +0000 quote
Thanks. I'll have a look through that when I'm not on my phone.
Sat, 23 Apr 2022 10:48:36 +0000
2016 Sprint 50
2016 Sprint 50
Sat, 23 Apr 2022 10:48:36 +0000 quote
You don't have to mix in an et2. The oil is pumped from the oil reservoir. There is a belt to run the pump
Sat, 23 Apr 2022 12:41:17 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sat, 23 Apr 2022 12:41:17 +0000 quote
Yes it has an oil pump, so generally you wouldn't need to mix but in this case the engine bearings seem to have seized and I know the oil tank was full of some nice oil. So I'm happy to ignore the oiling system and just pre-mix the fuel until I can get everything sorted.
1:40 or better seems to be the go based on this post:
https://modernvespa.com/forum/topic172565
Sun, 24 Apr 2022 06:11:18 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sun, 24 Apr 2022 06:11:18 +0000 quote
Well, engine is out. Now it can sit on my workbench until I finish my last project. Then I'll have some room to pull it all apart.
Mon, 25 Apr 2022 19:28:46 +0000
2016 Sprint 50
2016 Sprint 50
Mon, 25 Apr 2022 19:28:46 +0000 quote
Sorry Bob. I misunderstood.
⬆️    About 6w elapsed between posts    ⬇️
Sun, 05 Jun 2022 21:14:30 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sun, 05 Jun 2022 21:14:30 +0000 quote
I removed the drive pulleys, flywheel, stator, oil pump and starter motor on the weekend.
Tonight I'll try split the casing. I don't have the special tools, so I'll make do with some scrap steel and a heat gun. I bought an IR thermometer yesterday to give some level of accuracy on heading up the casing.
What could possibly go wrong?
Sun, 05 Jun 2022 22:42:20 +0000
Moderibbit
Moderibbit
Sun, 05 Jun 2022 22:42:20 +0000 quote
Good luck! Unfortunately this isn't a terribly uncommon exercise on vintage bikes ("sat 30 years", yadda yadda) so have courage - the et2 has a simple and sturdy motor, so if the casings aren't trash and you can get the bearings needed you should be able to get it done
Sun, 05 Jun 2022 23:03:40 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sun, 05 Jun 2022 23:03:40 +0000 quote
Thanks. I'm not expecting anything too drastic but things can always go sideways if you stuff it up enough.
Once it's apart I'll be able to order what I need to get it going again.
Can anyone recommend who to get parts from? I'm in Australia but I'm aware sourcing from overseas may be required.
I'll need a full rebuild set, so crank, piston, bearings, seal, intake manifold etc. There's probably more so I'll have to try sort out a complete list of what I'll need.
Sun, 05 Jun 2022 23:08:33 +0000
Sun, 05 Jun 2022 23:08:33 +0000 quote
Before going any further... I would be tempted to call up some local Vespa shops, and see if they have any ET4 150cc parts bikes lying around... if you're gonna take apart, rebuild, and reinstall a motor... might be worth just swapping in the 150 parts, get yourself a seriously sweet power upgrade.
This guy says it took him 3 hours:
Sun, 05 Jun 2022 23:16:59 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Sun, 05 Jun 2022 23:16:59 +0000 quote
Over here I can drive a 50cc on a car license. If I start going for stuff like that I need a motorbike license.
I'm not after anything fast. I just want something cheap to take to the shops etc.
I have cars for if I want a speed hit (which already take up too much time and money )
Mon, 06 Jun 2022 07:24:34 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Mon, 06 Jun 2022 07:24:34 +0000 quote
Ok, the support from my tranny jack looks the right size. And I've found some bolts that should work. Here goes nothing.
Mon, 06 Jun 2022 07:40:58 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Mon, 06 Jun 2022 07:40:58 +0000 quote
Well, that was easy. Heat it up to 90 and it came off with minimal effort.
Mon, 06 Jun 2022 08:03:06 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Mon, 06 Jun 2022 08:03:06 +0000 quote
I'm going to say this thing has been opened before. There is residue on the surfaces and maybe a very thin layer of sealant. The main bearings spin pretty free, but there's side play in them. The crank to rod bearing is tight and not moving at all.
Mon, 06 Jun 2022 08:17:08 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Mon, 06 Jun 2022 08:17:08 +0000 quote
There is noticeable wear on the drive side splines. If the splines are worn, it's a good guess the teeth on the cogs are worn also yes? Do I need to replace these?
Mon, 06 Jun 2022 09:27:52 +0000
Mon, 06 Jun 2022 09:27:52 +0000 quote
For good measure I'd replace the pulley half and back plate. Don't want those ruining the crank.
Mon, 06 Jun 2022 09:40:01 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Mon, 06 Jun 2022 09:40:01 +0000 quote
Thanks. I figures they'd need replacing.
I had no idea what they were called, so now I know what I'm searching for.
Tue, 07 Jun 2022 00:45:05 +0000
Tue, 07 Jun 2022 00:45:05 +0000 quote
Mine looked the same (7500km) and I think they're shaped like that from new.
Here's a pic from a UK retailer's site. Is this the wear you're referring to? If so, nothing to worry about.
If you look at where those areas are: to the rear, there's a washer (in front of the oil pump belt cog thingy); and on the much larger flat spot, your variator bush (drive face boss). Guess they're machined that way to accommodate those items.
A bit of fine sandpaper on the variator surfaces (to get rid of rubber deposits and shiny/polished bits), and a good polish inside of the variator basket (for smooth movement of the rollers).
Saves you a few AUD. 👍
Tue, 07 Jun 2022 02:46:57 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Tue, 07 Jun 2022 02:46:57 +0000 quote
I did notice that when I was looking last night. I may throw those $$$ saved at a 70cc kit instead.
Tue, 07 Jun 2022 15:44:05 +0000
Tue, 07 Jun 2022 15:44:05 +0000 quote
Well worth it. Makes it a lot more usable in modern traffic.
If you do, save yourself a lot of grief/money and stick with the Weber 12mm carb. The PHVA 17.5 is a PITA to set up. 🙈
Your stock exhaust will be fine with a 70cc cast iron kit (as long as it's de-resricted). But you can do better.
Now, obviously that makes your machine a motorcycle, as opposed to ped. Your license may/may not allow it. 🙃
There are higher tuned 50cc kits that you can get, but they involve a bit of work to get the power/usability of the 70cc.
Easy to get sucked in (I'm certainly guilty).
Tue, 07 Jun 2022 16:02:35 +0000
Moderibbit
Moderibbit
Tue, 07 Jun 2022 16:02:35 +0000 quote
+1 from experience
Also agree, your splines are fine
Tue, 07 Jun 2022 17:48:52 +0000
Tue, 07 Jun 2022 17:48:52 +0000 quote
xantufrog wrote:
+1 from experience
Haha - I saw your thread… thought, maybe an could do a Fabio, but no.
Guess I'm just a mere mortal. 🤣
Tue, 07 Jun 2022 17:57:03 +0000
Moderibbit
Moderibbit
Tue, 07 Jun 2022 17:57:03 +0000 quote
A lot of people do it but I really don't think it's worth it unless going for a more aggressive kit and pipe and going all out. The thing to keep in mind is the point of the bigger carb is to increase overall volume of pass-through. If the carb can feed enough air per rev for the build then throwing a bigger carb on gets you absolutely nothing.
I was happier in the end just putting the 12 back on and tuning the carb! Coulda saved a bunch of headache and just spent more time enjoying it (I think I played with 3 cylinder kits, two pipes, and the two carbs, along with variator tweaks, before I wound up de-tuning it a bit and remembering that I wasn't building a drag bike )
Tue, 07 Jun 2022 18:31:26 +0000
Tue, 07 Jun 2022 18:31:26 +0000 quote
I can ride anything I want with my motorcycle licence… but I love this thing.
I won't do this (unless I have a mid-life crisis?), but there's something very appealing about a tiny scoot, with a tiny cylinder revving up to 12k rpm… letting rip everywhere it goes.
The revs, the smell, and the sound (papappapappapapapapap). 💨💨Cracking.
A Malossi RC One ET2 would be SO wrong but absolutely fabulous at the same time. 😇
Tue, 07 Jun 2022 18:33:59 +0000
Moderibbit
Moderibbit
Tue, 07 Jun 2022 18:33:59 +0000 quote
Oh yeah, small bikes going fast(ish) can be a lot more fun than big bikes going the same speed!
Tue, 07 Jun 2022 18:58:05 +0000
Tue, 07 Jun 2022 18:58:05 +0000 quote
Following along as I was given a seized 2001 ET2. Wasn't too bad buying go faster parts but I splurged for the 70cc Malossi, multivar kit for just under $300. Decided to keep going down the rabbit hole and ordered the Wild Lion exhaust and 19mm carb.
Not necessary to do the deep dive but I also heard how positive just the simple 70cc top end swap is.
Tue, 07 Jun 2022 19:18:52 +0000
Tue, 07 Jun 2022 19:18:52 +0000 quote
How does the Wild Lion exhaust (AKA Gianelli Go) perform on the kit compared to a stock derestricted exhaust?
Keen on something to aid the Malossi 70cc kit without being shouty (in looks, or sound).
Tue, 07 Jun 2022 19:25:10 +0000
Tue, 07 Jun 2022 19:25:10 +0000 quote
No idea. Haven't installed yet. Busy with work and the family. Hopefully will have time to play with it in the next few weeks.
Tue, 07 Jun 2022 21:19:30 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Tue, 07 Jun 2022 21:19:30 +0000 quote
I was talking to a mate at work about it. He has a motorbike, but was contemplating grabbing a cheap scooter a mate offered him as you can fit the shopping under the seat and a carton of beer between your feet. Much less hassle than the full size bike too for a 1km trip to the shops.
I'll be keeping the stock exhaust (delimited already) as I don't really want to bring attention by making the bike look modified. If it hits 60km/h then that's plenty for what I need.
I just checked and my ET2 doesn't have a fuel tap. Since it doesn't have one from factory I'm guessing it doesn't really need one then?
Tue, 07 Jun 2022 21:33:46 +0000
Tue, 07 Jun 2022 21:33:46 +0000 quote
Should have a vacuum operated fuel tap on the right side over the exhaust. You'll see the hoses curve around to the left side of the scoot with one going to the carb and the other running to the intake manifold.
Tue, 07 Jun 2022 21:44:08 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Tue, 07 Jun 2022 21:44:08 +0000 quote
The Malossi 70cc kit included this little gem:
**When installing a 70cc kit it is necessary to increase the jet size in the carburetor. Failure to do so may cause engine damage.
I know every case is different, but if I'm going with just a 70cc kit and everything stock, what jet should I be aiming for. I'm also removing the oiling system and going to premix. Will this affect the jet sizing?
Tue, 07 Jun 2022 21:45:51 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Tue, 07 Jun 2022 21:45:51 +0000 quote
Ahh, yep I saw that bit with the two hoses coming off it. I didn't realise that was it. Too simple.
Tue, 07 Jun 2022 21:58:24 +0000
Tue, 07 Jun 2022 21:58:24 +0000 quote
Always makes me chuckle the fuel tap is over the exhaust. Nothing like a heat source and gas
Tue, 07 Jun 2022 23:08:50 +0000
Vespa ET2 50cc
Vespa ET2 50cc
Tue, 07 Jun 2022 23:08:50 +0000 quote
OK, so this 70cc kit is half the price of the Malossi kit and it has an aluminum barrel. A quick google doesn't bring up anything bad about the Airsal brand, but it sill raises a flag in my head. I'm assuming the liner would still be steel, otherwise it'd wear pretty quick. Any feedback?
https://www.maxiscoot.com/en/product/airsal-cylinder-kit-sport-70cc-aluminum-piaggio-typhoon-stalker-28346?vctype_id=13
  DoubleGood Design
[ Time: 0.0363s ][ Queries: 6 (0.0087s) ][ Debug on ][ 277 ][ Thing Two ]
