Does the power usage of the bulbs have any real effect on the bikes performance or accessories?
Is there a special procedure for installing the OSRAM LED bulbs? Those have little prongs to connect vs fixed base plugs of traditional bulbs. It looks like we would just slot the little paddles into the appropriate terminal of the bulb-sockets that the traditional bulb would have plugged into. Do the little paddles need anything special to hold them in the plug slots?
The Philips H7 X-tremeVision currently installed uses about 55 Watts
https://www.amazon.com/gp/product/B00RZKIZ0U/
The OSRAM 67210CW LEDriving HL Gen2, H7 uses 14 Watts
https://www.amazon.com/dp/B07P5NRV1K
Would the reduced electrical load of the LED help improve fuel economy or power? My guess is any change would be negligible in relation to engine loading and performance.
Would 41 watts freed up by switching to LED then be available to power fancier accessories (USB plugs, heated gear) without disrupting the bikes ability to charge the battery?
The current bulbs are very bright and work perfectly fine with allot of life left in them. The LED bulbs are tempting but I can only really justify a swap if there is some secondary benefit beyond "LED is cool"
