Tue Apr 26, 2022 10:18 am
Piaggio Fly125 2005
Piaggio Fly125 2005
Tue Apr 26, 2022 10:18 am linkquote
Hello everybody!
My name is Kamil.
I have a problem with my Piaggio fly 125 2005, engine code m421- milage ~14k kilometers.
The engine starts and heat up perfectly, problem is with low power/low rpm, he can't hit more speed than 40km/h. On stand looks like everything goes right - engine hits low/middle rpm's slighly but not on the road.
What i done:
1. I cleaned carburettor (KEIHIN CVEK26), flow screw - turned twice from the close position. Also replaced vacuum valve to factory new (somebody can tell me how it work /should works?)
2. Changed to new one: fuel supply pipe, fuel valve low-pressure pipe, SAS pipe, air filter, spark plug - claerance 0.8mm
3. I set up claerance on valves in head : intake 0.10, outlet 0.15
4. I sealed air filter box with new bands - engine not respond for autostart spray.
5. Sometimes when I rev engine, it shoots in to exhaust system
6. I haven't looked yet under transmission cover - maybe here is a problem ?
Here is my video - maybe you'll catch something that I missed.
https://youtube.com/shorts/FKy-hHkrDYM?feature=share
Tue Apr 26, 2022 12:59 pm
Primavera 150
Primavera 150
Tue Apr 26, 2022 12:59 pm linkquote
Check the engine compression.
Thu Apr 28, 2022 8:36 am
Piaggio Fly125 2005
Piaggio Fly125 2005
Thu Apr 28, 2022 8:36 am linkquote
Done, ~9,8 bar on guage.
I looked up behind cover, everything looks ok but transmission belt has cracks on tooth's i need to replace him. Belt had numbers - Dayco 22,5x814 LE 8118K 09033186 - is that right for my engine ?
Thu May 05, 2022 9:59 am
Piaggio Fly125 2005
Piaggio Fly125 2005
Thu May 05, 2022 9:59 am linkquote
Another update
I found crack on rubber manifold witch connect carburettor with cylinder.
I replaced it to new one, urfontunately did not help.
Now im in critical point, i have no idea what else to do.
Thu May 05, 2022 1:59 pm
Thu May 05, 2022 1:59 pm linkquote
The engine seems like it is revving freely enough. Have you taken a look at the belt/rollers/clutch?
Sat May 14, 2022 7:25 am
Piaggio Fly125 2005
Piaggio Fly125 2005
Sat May 14, 2022 7:25 am linkquote
Yep, everything looks good, but belt need's replacement. I can see crack between tooths on them.
My problem is solved.
I filled up can with 3liters cold water, add 100ml multipourpose cleaner called "DIMER" in Poland, and throw the carburettor into this mixture.
After 3 days, carburettor was taken out from can, cleaned with compressed air. Then i put together all parts of carb. I set it up into rubber manifold and voilĂ  ! it's works perfectly.
During assemble carb i meet one problem - the rubber of the vacuum valve does not fit well with the seat, its taken me a few minutes for it to sit well and it worked.
I think it's of problem with some dirt in carb or bad fitment with rubber from vacuum valve - now engine works great and again give fun on ride the scooter
Thanks for all Users to tryed help me. Cheers!
Sat May 14, 2022 12:31 pm
'70 Super 150, Aprilia SR MT 125, Moto Guzzi Bellagio
Sat May 14, 2022 12:31 pm linkquote
Well done
  DoubleGood Vespa Design
[ Time: 0.0330s ][ Queries: 5 (0.0111s) ][ Debug on ][ 211 ][ Thing One ]
