2007 LXV150
2007 LXV150
i thought it was the battery dying but i keep charging it to 100% and then this happens the next time i try to kick it on a few days later. there is oil at the level according to the dipstick and naturally there is plenty of fuel in the tank.
https://www.dropbox.com/s/krya8mictq8n3j5/Vespa%20issues%20-%20shorter%20sample.m4a?dl=0
thanks!
@jkj-fz6 avatar
@jkj-fz6 avatar
1. Does it start right after you charge the battery?
2. What's going on in the time between charging the battery and you "try to kick it on a few days later"?
3. How old is the battery?
4. Can you get some voltage measurements from the battery: while it's on a charger, after it's been charged, and while it's trying to start the scooter?
I'm thinking your battery is on its last legs.
2007 LX150
2007 LX150
Your bendix starter gear isn't engaging. You can either take it out and clean it, which sometimes helps, or replace it altogether.
https://www.scooterwest.com/bendix-pinion-starter-gear-150-200cc-vespa-and-piaggio-580446-82612r.html
@greasy125 avatar
@greasy125 avatar
even if the battery is showing full charge it may not have the amps to kick it over.
also, if it's 07 and you've got mileage it may be time for a transmission service.
I'd strongly suggest a new battery and having a peek at the transmission components.
@madison_sully avatar
I'd be thinking dead battery.
Replace with new and you'll be fine.
It has nothing to do with fuel (yet), as the crank never actually turns.
2007 LXV150
2007 LXV150
thanks ya'll! battery ordered, will followup if it didn't help.
[ Time: 0.0103s ][ Queries: 3 (0.0027s) ][ live ][ 313 ][ ThingOne ]
