Sat Apr 30, 2022 2:26 pm
Piaggio mp3 500
Piaggio mp3 500
Sat Apr 30, 2022 2:26 pm linkquote
stupidly set the battery charger to wrong setting to charge battery while installed on the bike!! shorted out the bike! put a new a new battery as per Doug! now when I turn on the key, the fan turns on, all four turn signal light up, the bike will not start! checked out both sets of fuses! one 20 amp fuse needed replacing! Still same problem!
Sat Apr 30, 2022 5:21 pm
Fri May 06, 2022 9:16 am
Piaggio mp3 500
Piaggio mp3 500
Fri May 06, 2022 9:16 am linkquote
found the hidden fuse! It was blown! but no spare in the fuse case! Had one to use! Now when I replace the battery cable I get a spark! OAD told me it probably a burnt connection (my words) somewhere ! One of his buddies who was listening said if I knew which fuse blew it would be easier to trace the wiring ! There are two yellow 20amp fuses in the fuse box by the battery but I do not remember which one it was! Any ideas?
Fri May 06, 2022 2:23 pm
  DoubleGood Vespa Design
[ Time: 0.0269s ][ Queries: 5 (0.0079s) ][ Debug on ][ 211 ][ Thing One ]
