@dunkyc avatar
Gts300 Supertech
@dunkyc avatar
Gts300 Supertech
Purchased a new 75th Anniversary Vespa GTS300 Supertech, it was meant to be for my girlfriend but she is still to pass her A2 meaning I am now a scooter isn't. When I first picked up the Vespa at the end of a ride it made a noise like a boiling kettle letting off steam. I looked online and it sounded like the overfill when I had refuelled. I carefully ran it in but at under 500 miles the dash spanner came on whilst doing a first two up ride. I went to the local dealer in Canterbury who are a Vespa dealer and are what I would call a proper old school motorbike shop. The Vespa was due a first service so two birds with one stone, the fault was a sensor that was something to do with the water pump. I think the sensor sends false data and the cooling system tries to react. Anyway sensor changed under warranty now at just under 1000 miles and the noise is back. When I stop the noise an intermittent noise like a kettle that briefly boils and let's the excess steam off then goes back to silence. I normally ride a Ducati desert sled and don't have any issues with water related noises (as air cooled v-twin), nor any other noises when I park up. The Supertech is a great ride and you can throw it into the corners. There is a flat spot when I throttle off where the engine feels like it is hunting, but I have just out this down to it being something in the ECU. Hopefully some Vespa genius can tell me the sensor is a known problem and hope that it is just a bad batch? Anyway that's my first post done!
@touring300 avatar
@touring300 avatar
Welcome to Modern Vespa. The issue you are describing sounds like the radiator fan swiching on and off. When the water cooled system exceeds a certain temperature the fan kicks in automatically. It normally happens when the scooter is stood for any length of time like in conjested traffic. I have not heard anything thing about a bad batch of temperature sensors, perhaps the replacement your dealer fitted will cure the problem, if it is indeed a problem.
@coddy avatar
@coddy avatar
Yes I agree, my fan came on for the first time yesterday which sounds exactly what you describe. Luckily I have been riding modern Triumph motorcycles for the last few years so knew what it was or like you I would of wondered what on earth that noise was.
Welcome to the forum.
@dunkyc avatar
Gts300 Supertech
@dunkyc avatar
Gts300 Supertech
Thanks, the lack of the spanner must mean it is the fan rather than another sensor. Happy days then.
the spanner is not a fault indicator. it is a reminder that you are due for a service.
[ Time: 0.0082s ][ Queries: 4 (0.0021s) ][ live ][ 343 ][ ThingOne ]
