@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
Is this a rivet or something else that can be easily removed… gave it a couple of tugs but didn't want to force it off.
@mopedlar avatar
2001 GTS Super (white), 2021 GTS Super (yellow), 2013 LX 50, 1986 Honda Helix, 1976 Bianchi Snark moped, 1980 General 5 Star moped
@mopedlar avatar
Just drill the rivet out. Takes all of two seconds to do it.
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
More concerned with reattaching..
@rottekatz avatar
Primavera 150
@rottekatz avatar
Primavera 150
They look like pop rivets. If so, easy to replace if you have the tool.
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
A pop rivet tool is available cheaply at Harbor Freight. That particular rivet has a very wide head - you'd need to look around a little for a replacement.
You might be able to find a way to replace it with a snap.
Once it comes off it will probably never go back on as tightly. Why do you want to take it off? (My '09 S has a strap like this and I'm not crazy about the look.)
Does anyone use these things? It seems like a pain in the ass.
@shebalba avatar
@shebalba avatar
You most likely have already looked into this, but I would make sure the seat has not sun faded just enough so that the area under the strap is a different color and you end up with a racing stripe you didn't really want.
That would send my OCD into a tailspin and I'd be posting 'Seat strap installation.. rivet?' and to the 'What's Pissing You Off II' thread.
@25bikez avatar
2009 Genuine Stella 2T (Sold). Helix Hunting.
@25bikez avatar
Drill it out.
If you ever need to put the strap back on, you can screw a short, wide sheet metal screw directly into the seat base plastic or use a hobby stapler.
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
I had this exact question but was afraid to ask it. Thanks for being braver than me. So, it IS a rivet. It can be drilled to remove it and it can be replaced by a sheet metal screw. Life is good.
If someone were to carry a pillion using the strap as a hand hold, staples or a sheet metal screw might fail.
Yeah, does anyone use it for that?
OP is it because you're sitting on it or just cosmetic?
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
I bought a used model S seat for my ET4 because I think it looks nicer than the stock seat. The strap on the used seat is bunched in the middle a bit as if the previous owner used the strap to lift the bike onto its center stand. If I remove the strap I can flatten it and reuse it, I think. It needs to be on the seat because there is a bit of a color difference between the seat and the area of the seat under the strap (probably discoloration from the sun). The strap will cover this as it always has. So yeah, it's all basically cosmetic.
@rickster333 avatar
2001 ET4 "Mona"
@rickster333 avatar
2001 ET4 "Mona"
LOL! Yeah, me too!
@juan_orhea avatar
@juan_orhea avatar
That strap may just be cosmetic but it's definitely not intended for a pillion handhold. The seat design looks sporty, but it really doesn't accommodate a pillion very comfortably. I assumed the strap is there to steady the scoot as it's going up or down on the center stand.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Just be sure that the drill used is short enough that it won't go through the seat.
@der_blechfahrer avatar
I've removed the strap and I regretted it.
I did remove it, because there was always water trapped under the strap from dew or rain. Also because of the looks. The rivets can be drilled out easily. Reinstall was a nightmare.
The strap is useless to hold onto, but it needs to be there for legal reasons, if your Vespa doesn't come with a grabrail, like the model S did. Was a problem when I tried to sell the seat.
I did find pop rivets with a large head, but they were a bit smaller and wouldn't sit. Screws didn't work either. Eventually, I did find a buyer that took the seat without the strap.
A cheap and easy way to satisfy the DOT requirement for passenger handholds brought us this useless item. It's a lousy handhold that appears in lieu of side rails or integrated handles.
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
The color is not the same as the seat… not sure if I'll match it but if I see something closer it comes off!
[ Time: 0.0099s ][ Queries: 4 (0.0037s) ][ live ][ 343 ][ ThingOne ]
