ok will i think im going to do some kind of mod if possible... im about to unhook rear blinkers and rewire those 2 wires to the built in side running lights to make them the blinker like euro style.. thus creating 2 HOT wires that will be isolated and cut.. now... add a 9v adapter with mount while key is on i should have a nice charging port any reason this would not work? it also removes any issue with dealing with a hot wire that has to be terminated and sealed off...
Posts: 432 Location: Dahlonega, GA |
archtop67 wrote: ok will i think im going to do some kind of mod if possible... im about to unhook rear blinkers and rewire those 2 wires to the built in side running lights to make them the blinker like euro style.. thus creating 2 HOT wires that will be isolated and cut.. now... add a 9v adapter with mount while key is on i should have a nice charging port any reason this would not work? it also removes any issue with dealing with a hot wire that has to be terminated and sealed off... |
rdhood wrote: And, as the previous poster mentioned, there is already a charging port in the glove box. |
Posts: 2177 Location: Lancaster, U.K. |
Corn wrote: Does anyone know what year GTS this started in? |
Red Devil SH150i (11,000)
Posts: 3341 Location: Orange Park Florida |
Once you start cutting into the wiring that salt air is going to eat those wires. I doubt Vespa uses tin coated wiring.
How about one of these. https://www.amazon.com/30000mAh-Portable-Charger-Stylish-Compact/dp/B08D9JR8TR/ref=asc_df_B08D9JR8TR/?tag=hyprod-20&linkCode=df0&hvadid=475811884312&hvpos=&hvnetw=g&hvrand=14868452867863421796&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011476&hvtargid=pla-1088707255179&psc=1 |
breaknwind wrote: Once you start cutting into the wiring that salt air is going to eat those wires. I doubt Vespa uses tin coated wiring. How about one of these. https://www.amazon.com/30000mAh-Portable-Charger-Stylish-Compact/dp/B08D9JR8TR/ref=asc_df_B08D9JR8TR/?tag=hyprod-20&linkCode=df0&hvadid=475811884312&hvpos=&hvnetw=g&hvrand=14868452867863421796&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011476&hvtargid=pla-1088707255179&psc=1 |
