@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Vespa gts300 not starting I checked it. It has Fuel, Spark, Compression and key detected. I removed evap system checked the fuel pump and fuel injectors it works, I checked piston still amazing new, I adjusted the valves, I did the timing at TDC, I replaced air filter and oil filter
2015 MP3 500 ie Business
Wrong forum section. You are in the MP3 section.
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Sorry do you know which section I have to post that in?
@jkj-fz6 avatar
@jkj-fz6 avatar
Post in the General Discussion forum.
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Thank you man appreciate it
[ Time: 0.0084s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
