Does anyone know or can recommend the preparation procedures for moving a vespa, we are moving from South Africa to Europe , the bike will be in a container on board, should we drain the oil and put preservation oil or leave with normal engine oil. Expected time between Departure and destination points is 57 days.
When I shipped bikes in the past, it was minimal/no fuel and leave oil full.
I am trying to remember about the battery, but I would disconnect either way unless going by air. Might disconnect negative cable. |
Posts: 2126 Location: Lancaster, U.K. |
Having shipped my GTS twice before, I highly recommend that you have your ET4 case packed (put into a bespoke timber box)*. This will give it full protection and it can then be moved around by fork-lift truck. If you 'lose load' it inside the shipping container, you run a high risk that other items inside the container will come into contact with your scooter and dent or scratch your paintwork. Run the fuel down, but leave a few litres of petrol in the tank. You don't need to do anything with the oil. Disconnecting the battery is also a good idea as marret suggests.
*Make sure the timber used is heat treated and marked as such to comply with EU important regulations. **You can use wasted space around and on top of your scooter with items such as bedding/cushions/pillows/clothing. Filling out the space in this way will also prevent any movement of your scooter inside the case. I can't advise on importation procedures, but you will probably need to produce a copy of the vehicle registration certificate (log book), and maybe a certificate of export from the SA vehicle licencing department. |
Is there any chance a local Vespa dealer will sell / give you the packing crate from a new delivery?
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
Christopher_55934 wrote: I agree pallet it up and build a wooden box around it with a frame. |
GTS 300ABS, Buddy Kick 125
Posts: 13560 Location: Oregon City, OR |
marret wrote: I am trying to remember about the battery, but I would disconnect either way unless going by air. Might disconnect negative cable. |
Dooglas wrote: If the battery is the older liquid filled type, I would remove it. If the battery is a gel cell type, I think you can leave it in, but I would still disconnect the negative lead as marret suggests. |
Posts: 1575 Location: Denver |
I shipped a scooter from Colorado to Hawaii via air freight. The carrier would not do it unless the scoother (Elite SR50) was crated by a Honda dealer. You should be asking the carrier this question.
