Vespa GTS Super HPE
Vespa GTS Super HPE
2020 GTS started and died within 5 seconds today. ECU light stays on.
After that, it wouldn't crank several times, then it started and died again immediately.
Tried reseating fuel cap, and verified battery terminals and plug cap are snug.
Fuses in the glove box are fine.
Ideas appreciated.
⚠️ Last edited by cat herder on UTC; edited 1 time
Sounds like the battery... Charge it up, then do the usual checks on the charging system.
Diagnosing Charging System Problems
Oh, and remember NOT to twist the throttle when attempting to start.
Vespa GTS Super HPE
Vespa GTS Super HPE
Battery is fresh, along with 24 month service done two months ago. It doesn't crank a few times then it cranks normally, starts and dies in a few seconds.
Might have to get it to the dealer.
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
I'm having the same problem with my GTS300 ie I would check the spark plug make sure it's not black on the tip
Vespa GTS Super HPE
Vespa GTS Super HPE
Dealer says the tip over sensor failed.
Ordered from Italy. Will be a while.
Unplug it and ride.
The engine runs happily with it unplugged, coincidentally i tried this recently (admittedly i only started the engine and revved it a bit on the stand, i didn't actually ride)
[ Time: 0.0104s ][ Queries: 3 (0.0039s) ][ live ][ 343 ][ ThingOne ]
