@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
No matter what I do my new spark plug always comes out black had a pack of 10 they all came out black I'm getting spark fuel and good compression no matter what I do I can't get my scooter to turn on for more than 2 seconds cause of this I cleaned out my ECU and still no luck I flushed the gas and added fresh 93 and still nothing anybody have any advice on what to do or check
⚠️ Last edited by Kennyk5 on UTC; edited 2 times
2022 Honda PCX 150A, 2018 GTS300 [sold] & 2015 GTS300 Super [sold]
Idk - Check the high tension wire for continuity/damage? Check the battery? I'm pretty sure I've had an HT wire that "looked" fine, but wasn't getting enough juice to the spark plug, resulting in lots of mis-starts and pissed-off attempts to restart, with the end result being a non-running scooter and fouled spark plugs. Does the scooter run and that spark plug is the result of the running engine? Or did you try to start the scooter 100 times, without success, and that spark plug is the result?
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Yeah I tried to start the scooter 100 times maybe literally and this was the attempt I had ran through 10 spark plugs and they all came out looking like this the scooter still is but starting
@kaukari avatar
GTS 300 ABS, 2018
@kaukari avatar
GTS 300 ABS, 2018
…and of course you have checked that your engine is getting air…😎
Is your battery strong?
If this was a carburetor bike, I would say it is way too rich/not enough air(too much choke or clogged air filter and maybe possible a ring problem allowing some oil in the mix. Is this a stock machine? That is, has anyone messed around with the injector, exhaust, or throttle position sensor?
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Does anybody know how can I check and make sure that the scooter is getting enough air to the engine I did a lot I'll tell you I flushed gas I got new spark plug I got new air and oil filter I adjusted the valves I did the timing I took apart the bike and checked the piston was all good I removed the evap system I checked fuel pump and fuel injectors it was all good I checked for compression it was perfect I cleaned the air port inside the ECU and the key gets detected but still no start…. 😕😐🥱 I watched all robots videos on what to do did it all and nothing nothing at all
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
And I have a battery charger with 2 batteries charged them both up to about 100% went downstairs cranked for about 10 min straight each battery and nothing it turns on but then dies down so rough the whole scooter shakes as it dies badly
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
This is the port I cleaned out for the air flow on both sides and it was massively dirty but still doesn't turn on
If you start it and then ride it off at decent revs does it die then? I'm still questioning the cleanliness of that idle bypass passage...
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Once I try to start it it goes on for like about 2 seconds then it just cuts off then would be hard to start again I cleaned it yesterday with carb cleaner then I used a high pressure air hose to finish the job and air was flowing freely I watched a video about black spark plugs it could only be 2 things I'm down to now either clogged or leaky fuel injectors because it's pushing to much gas onto the spark and it's not lighting it properly orrrr the 2nd thing they said it could be oil vapors sneaking past the piston and getting onto the spark plug which is not letting the spark actually spark up and do it's proper job
Oil vapours when it's cold sound very unlikely...
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Yesterday I had removed the fuel injector and tried to start it and there was a huge flame that just popped up from the injector port hole with a loud boom which I assume was the spark igniting the fuel that was left in there it was like a flame that came up was dangerous but I was just checking it out and it ignited it sooo there's only 2 things I guess I need to check out either clogged fuel injector or leaky or oil bypassing the piston and valves getting to the spark not letting it ignite cause like I said I took off the fuel injector from the port tried to start it and there was a big boom!! With a huge flame that came out of the hole
It's not a clogged injector (it'd run lean then), it must be a leaky one.
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
This is how my valves was looking when I first disabled the engine and my piston as well
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
Do you know how I fix a leaky fuel injector
@kennyk5 avatar
Vespa GTS300 ie
@kennyk5 avatar
Vespa GTS300 ie
And this is the valves
You don't fix a leaky injector - you change it. A partially blocked one can be cleaned and cleared, but a leaky one is beyond redemption.
[ Time: 0.0182s ][ Queries: 4 (0.0110s) ][ live ][ 343 ][ ThingOne ]
