Hey all,
I've got a question that I thought I'd bring to the experts.
I've got a 1960s Vespa large frame that I stuck a 2005 LML 2T motor onto many years ago.
It's recently picked up a weird issue that I'm not sure how to solve.
Runs like a top. Kicks over on the first kick. Idles great. If I ride it (as of the last two weeks) I can get maybe 4 blocks and then when I come to a stop the idle drops down really low and lopes along for 30 seconds or so until it dies. I can't rev it at all when this happens. After it dies, sometimes I can get it to start up again and run fine for another few blocks... Sometimes it won't come back to life for 5-10 minutes.
I put a spark tester in-between the plug wire and the plug and I can see, when it's misbehaving, that the spark appears to only be firing half the time.
I pulled the flywheel and the stator is visually fine. The pickup coil (which is external) shows a reading within spec (109 ohms), as does the low tension coil (380 Ohms). I thought the LT coil was low, but I found a spot online that shows that this stator plate (with a red CDI should show 400ohms, as opposed to the 500 I've seen on my other scooters).
When I spin the cold engine with a drill, I see about 111 volts AC on the low tension coil.
Any guesses?
Any help would be greatly appreciated.
-Bob
