@onevw avatar
2022 GTS Sport
@onevw avatar
2022 GTS Sport
I have ordered a 2022 GTS sport or a GTS super tech which every one gets available first.
Do these bikes have a way to see a gage of the Engine Temp or oil pressure?
Rick
warning lights for both oil and water temp.
The engine temp can also be accessed via Bluetooth on the Supertech. Using my own app I'm able to display the temp on the Supertech TFT dashboard
@onevw avatar
2022 GTS Sport
@onevw avatar
2022 GTS Sport
Many thanks for the Info.
Are you saying your software only works with the TFT display super tech buks?
Rick
Rick
It should work with any Vespa with Bluetooth and a TFT. I've only tested it on the Supertech but i suspect others such as Primavera S and Sprint S would also work.
@onevw avatar
2022 GTS Sport
@onevw avatar
2022 GTS Sport
So If the bike has the analog display with the small LCD but has the blutooth unit installed your program should work?
Rick
Both my app and the official app will be able to capture and display the data on your phone when the optional Bluetooth is installed. Neither is able to display anything on the small lcd, apps can only display info on the large tft.
[ Time: 0.0105s ][ Queries: 3 (0.0045s) ][ live ][ 343 ][ ThingOne ]
