⚠️ Last edited by BananaOne on UTC; edited 1 time
Hi guys! I have a mostly stock PX125E engine on a VBA frame. To fit the 10in wheelbase conversion I had to upgrade the exhaust because the stock one would not fit around the tire. The engine has a SI 20/20 Carb with a 160/BE3/98 main stack and a 45/140 idle jet. I can't seem to get rid of the bog/power loss that happens when I reach 1/4-1/3 throttle no matter where I set the idle adjust screw (from 1/2 turn out to 4.5 turns out). The aftermarket exhaust I bought here: https://www.scootermercato.com/Scooter-Parts/Simonini/SIM40301BL. Does anyone have a suggested starting place for an upjet? And do I need to upjet both, or just the main jet?
Moderibbit
Posts: 8891 Location: Atlanta, GA |
The idle jet will have its biggest impact from "closed" to ~1/4, where its impact becomes dwarfed by the main jet circuit. If you just changed the exhaust you can probably leave the idle jet size alone and compensate with the mixture screw to ensure safe closed-throttle behavior (stock should be ~1.5 turns out, so you'll be looking at at least that much), but you'll definitely want to update the main with a performance exhaust. Start high and work down
Innovator
Posts: 12626 Location: Nashville 186 Days Since Last Explosion |
Innovator
If you're ordering jets, pick up a BE5 atomizer as well. that will help with the lean transition at 1/4 throttle as well as the mid-range, which is probably also lean as well. This matters because when you roll off WOT, if that mid-range is too lean, that'll kill the top end and leave you stranded on the off ramp.
And if it's too rich at mid-throttle, you can go back to the BE3, but for $5, it's cheap insurance since you're already ordering.
Positive
Bogging just past 1/4 - 1/3 throttle points to the BE3 mixer tube being too lean. Try a BE5 instead.
Posts: 5354 Location: Oceanside, CA |
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
Posts: 278 Location: Madeira Island |
MJRally wrote: Let me confirm, did you leave the 10" tire on the PX motor, or did you change it to 8"? |
Correct, I think the front fork I swapped in is from a stella, but I still haven't found a way to properly mount the mudguard, if anyone has an idea that would be appreciated. BE5 atomizer and a 102 and 104 main jet are on the way.
Innovator
Innovator
BananaOne wrote: Correct, I think the front fork I swapped in is from a stella, but I still haven't found a way to properly mount the mudguard, if anyone has an idea that would be appreciated. BE5 atomizer and a 102 and 104 main jet are on the way. |
