2007 bv250
2007 bv250
hi all, I finally got my new to me scooter home. 2007 bv250. I have ridden about 300 mi.i need info on how to improve acceleration and top end speed. I really like the handling and weight of this bike. just need a little more omphf. I am very capable of doing my own wrenching, just don't know these bikes at all. any help appreciated. thanks pat m.
caddy pat wrote:
i need info on how to improve acceleration and top end speed. just need a little more omphf.
That would be moving up to a 350/400. Razz emoticon
Seriously, there's probably a way to tweak things, though most of what's been done, and what I see mods for is the Vespa side of things. But you're likely not the first.....
Oh, and welcome to MV...congrats on the scooter. BV's a fine specimen, regardless of the engine.
Add a 1mm washer against the variator bushing (Piaggio #831363), and insert 21x17x13g Dr Pulley sliders instead of the Piaggio rollers into the variator. Leave everything else stock. Much better acceleration - but you won't get the top speed up without adding more power to the engine.
You need a lot more power to get a meaningful increase in top speed. e.g. If you can go 80mph then you need at least 20% more power to go 85mph, as the power needed to overcome the drag is proportional to the cube of the velocity.
So stick with the far better acceleration.
Malossi variator and heavier clutch springs. The most you're going to get for the price.
11-12 gram rollers will liven it up if you want to keep it simple.
2007 bv250
2007 bv250
thank you all for the info. will try some of the suggestions. thanks pat
@bill_dog avatar
eeeee bip
BMW R1100RT The Problem Child Kymco Downtown 300 Honda Crossrunner 800 Benelli Imperiale 400.
eeeee bip
@bill_dog avatar
Seriously, don't waste your money.
Buy something faster.
@crazycarl avatar
@crazycarl avatar
The BV250 used the same Quasar engine found in the Vespa 250's of similar vintage.
To get any noticeable higher higher top speed, you need to get more power and taller gearing to take advantage of that extra power. There are cylinder kits and upgear kits that will get you there, but these are pretty costly. The Malossi V4 Head and Cylinder kit will provide a nice bump in power.
Without the V4 head and Cylinder kit, try slightly lighter rollers and a stiffer contra spring in the clutch will provide a bit more nip off the line as mentioned above. You might also consider upgrading the camshaft to increase valve lift duration to allow for better breathing. The stock camshaft for the Vespa 300 will drop right in for this boost.
nope
nope
@bill_dog avatar
eeeee bip
eeeee bip
@bill_dog avatar
Yes, however you're trying to get something that can't go much faster go a little bit faster, with the emphasis on the little it.
Try to quantify just how little performance you're going to gain against the cost and labour involved.
So you launch off the line a bit quicker ? So what ?
If I want to go faster, I buy something faster.
However, if it's about bragging rights then the argument is lost because it's not about performance, it's about you.
BV 350's are as cheap as chips, are as ugly as sin but will annihilate a GT250/300 in all departments - acceleration, top and and handling. I'd plump for one of those if you want to go faster.
The reason that new vehicles lose money is when an attempt is made to sell them the perception is that there's something wrong. Which isn't the case. It's the perception that's enough to knock the price.
[ Time: 0.0105s ][ Queries: 3 (0.0041s) ][ live ][ 343 ][ ThingOne ]
