Jkr22 wrote:
Thanks chandlerman. Spoiler alert! Potential dumb questions. How much should I be looking to pay for a px motor and what size? I assume second hand so does it matter what year? Be as specific as you want😁
Cost is a question that's much better answered by a local. And while I used to spend a decent amount of time in the UK, that definitely ain't me.
Ideally, find a P200 motor, but that'll almost certainly cost you more.
If you can find a P-series or LML 150 that someone has already put a 177 kit on (other than a DR), but not gone crazy with tuning, that's probably going to be your best bang-for-the-buck. It'll give you improved acceleration and a little bit of top end, but not reduce reliability if done well.
The P-series motors are also a lot easier to work on, especially for a newb since they're much easier to split and close up the cases, and will probably have 12V and maybe even electronic ignition over points.
Some of the LML's will have a reed instead of rotary, which makes them a great base platform for further tuning (but that's going to the Dark Side in a big way), but they sound different from a rotary, so depending on how much of an "authentic" Vespa you want, you may want to stick with rotary.
So lots to learn, but that should be enough to get you started searching. Hopefully someone on your side of the pond can provide suggestions on where to look, too.
