@maxx28 avatar
GTS 300 Super
@maxx28 avatar
GTS 300 Super
Almost 15K miles on the bike and never had a problem until a week ago when i got home and noticed the rear wheel is stuck when trying to push the bike by hand to park it. Since last transmission service was done at 8K miles, I decided to just go ahead and overhaul the transmission. Found the clutch assembly nut has come undone and was rubbing against the clutch bell. After all done i test rode the bike, what a difference new parts make, it rides so smooth.
Replaced cover case bearing
Found the problem, clutch assembly main nut come undone and rubbed against the clutch bell.
You can see where the nut rubbed on the clutch bell and caused the rear wheel to lock up.
New clutch assembly
New clutch assembly
@touring300 avatar
@touring300 avatar
Great work and nice clear pictures, thanks for sharing. I just wonder how the clutch nut came loose in the first place? - Did you use locktite on reassembly?
@grouper avatar
2020 GTS 300 hpe Touring
@grouper avatar
Well done. It is always interesting to see visual evidence that reveals the cause of a problem.
@strawberrysoda avatar
2022 GTS 300 SuperTech
Agreed! I find these kinds of mechanical step-by-step breakdowns (no pun intended) fascinating.
Thanks for sharing and glad your scoot's back up and running!
@maxx28 avatar
GTS 300 Super
@maxx28 avatar
GTS 300 Super
Thank you. I used brand new clutch that come with everything assembled.
Good man. And lucky man - I hate to think what would have happened if it had locked up at speed. Kudos
[ Time: 0.0154s ][ Queries: 4 (0.0061s) ][ live ][ 343 ][ ThingOne ]
