I have a 2016 GTS Super with what was an intermittent problem last week. Today it is DOA and left me stranded.
Since this issue has started the following changes have been observed:
1. sometimes it dies when idling - it never did this in the past (estimate about 1500-1700 RPM)
2. idles slower than in the past - (estimate about 900-1000 RPM)
3. turning key off then back to on results in no dash lights, no fuel pump, no starter clicking, nothing
Both keys behave the same way - key in and turned to ON - no dash lights.
No warning lights came on when the bike is/was running
When this started I thought it was a bad battery even though the battery tested as WEAK. I replaced the battery with a new one and thought my problem was solved until today.
The immobilizer light flashes about every 2 seconds. I think this is normal. When I insert the key in either the LOCK or OFF position the immobilizer continues to flash. When I turn the key to ON the immobilizer stops flashing. Yet nothing on the dash comes on.
The manual says"
"Each time the ignition key is removed from the OFF or LOCK position, protection system activates... When the key is turned to ON the engine block is only deactivated if the system recognizes the code in the key"
Since the light stops flashing when I turn the key to ON, I presume the immobilizer ring/system is reading the key code and deactivating the protection system.
The manual also says the protection system is activated when the RUN switch is clicked to OFF regardless of whether the ignition key is turned ON.
Does the immobilizer system stop all the dash lights from coming on?
If so, it seems that may be my problem.
However, before doing anything else I plan to check all the fuses with a multimeter.
Any ideas or advice is greatly appreciated.
