1968 VBB150
1968 VBB150
Hey Cool Cats and Kittens, I just scored a Blue 1991 1981 PX125!
It is going to live in TX and be my scoot around town method of transpo. I am about 200lbs and my 180SS is plenty fast for my taste.
SO what upgrades would make the most sense? I need to get up to about 50-55 quickly, but don't need to ever go faster. I'd like to keep costs under $1k.
Thanks in advance![/img]
⚠️ Last edited by dsnyder586 on UTC; edited 1 time
@swiss1939 avatar
@swiss1939 avatar
vmc stelvio, a new exhaust and call it a day. Oh.. and remove the dead weight on the back!
@greasy125 avatar
@greasy125 avatar
pull all the tat off it, there's 50lbs easy.
don't paint it. just rub that mess out and call it a day.
tubeless and new donuts.
I'm guessing that you're going to rebuild, so I'd say VMC or BGM or malossi 177. knock on a 24/24 or a G if you can find one. match up the carb box, no biggie. then big box/sip road or a noisemaker if you want-- simonini actually make power and are cheap. if you feeling frisky? drop a cut crank in. I'd splash the pot on a cosa and call it soup.
that should be sub 1K and take what's left to the bar to buy daiquiris while watching the ball game.
Damn that will be a great ride with a 177 and pipe! And what a great color!
1968 VBB150
1968 VBB150
I LOVE that color, cant wait
1968 VBB150
1968 VBB150
I am leaning Cosa clutch, 177 and a 20/20 and call it good?
Should I hassle with gearing above the Cosa change?
I have never done the Cosa so can't comment.
I would *think* it'd be a decent upgrade though.
20/20 should be good enough. 24/24 maybe... if you go crazy on the pipe.
@greasy125 avatar
@greasy125 avatar
cosa, yes. I'd probably bump it up to a 21 or 22 if you can
with a 177, a 24 would probably be a better fit. the 20 will work, but it'll run out of huff pretty quick and with the short gearing you'd be looking at 55ish max. it'd get there quick though!
if it's just an around town bike, like you're not touring or taking road trips I wouldn't mess with the gears unless they need replaced.
Would know way better than I on the best carby. I didn't like the 24/24 on my 177, but I am also lazy and gave up before it was ever jetted in proper,
@greasy125 avatar
@greasy125 avatar
the 24's can sometimes be a pain in the dick to dial in. I'd splash the pot and go for a G with the T5 lid and filter.
that being said, one of the smoothest and quickest bikes I ever rode was a bone stock P2 with a 20/20. while it topped out at 55 indicated it felt like it wanted to lift the front wheel in 2nd and hustled every damn gear.
so a 20 will work. but me, being me, I'd go 24 just because. and just to be preposterous, probably a simonini. or, like a pitone if I could find one. I mean, in for a penny, in for a pound might as well be silly about it.
Great find. My 1980 mk1 p125 was always good for 55mph and that was standard apart from a 80s Fresco expansion . Sure miss that scooter, bought it second hand in 1983 and it was mint with only 800 miles on clock for half the price of a brand new one. I know standard pipes are lack lustre but I loved how smooth and quiet it was with standard pipe. Congrats on your new addition.
Honda CR80 clutch disk page, what have you got?
Butter here...
You might want to look at this before you commit. I think you might like a CR80 enhanced 7 spring clutch if you have or can get a 21 or 22 tooth core to rebuild. Cheap, effective and fairly easy. Have you tried this yet Greasy?
Cosa clutch w/ CR disks is the King 👑 of course if you really need to go first class.
Agree on the lovely colour, one of my very favorites!
1968 VBB150
1968 VBB150
Butter here...
....I LIKE where this is going.... Wallet will be open mid-late June.
*cough cough*
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
For God Sakes whatever you do, leave the blue color alone man! ROFL emoticon
@almogavar69 avatar
1987 Motovespa do Brasil PX200 elestart, 1979 P200E
@almogavar69 avatar
that includes the tail light !!!
1968 VBB150
1968 VBB150
More pics
@swiss1939 avatar
@swiss1939 avatar
dsnyder586 wrote:
More pics
Give that thing a bath!
It will look purdy when done.
1968 VBB150
1968 VBB150
I'm not out that way until July, but I'm going to give it a thorough cleaning
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Durdy N Purdy
@greasy125 avatar
@greasy125 avatar
*cough cough*
plz to txt kajiit... has wares... the clutch department is currently overstocked. I'll poke around and see if there's any other tasty bits and bobs....
1968 VBB150
1968 VBB150
I have coin. And need wares
1968 VBB150
1968 VBB150
UPDATE TIIIIME!!!!
Rolled up to a dusty P125, not started since 2008. I *thought* the motor was frozen, so expected to have to evaporust and heat things up, but it kicked fine. Hmm.
2 stroke into the cylinder and some kicks to get the cylinder lubed. No start. Open tank- empty. Hmm.
regular gas (its an auto lube) and 1/2 gallon of premix to keep it real. dribbled a little into the carb top and....
VROOOOOOM. Hot diggity.
Pull in the clutch and she stalls immediately. Uh oh. clutch is not engaging. Quick message to Voodoo and he mentions atf. Drain and fill, then warm up running. VOILA~ Clutch now working.
Tires are oooold and cracked, but I was able to take it for a ride. Runs and shifts just fine. (I have replacements)
Drain and fill with regular oil and all is well. seals do NOT seem to be leaking, it idles perfectly. Now for some wash and wax and I should be able to ride!! Do I swap a P200 lump in? Time will tell.
Pics for effect.
1968 VBB150
1968 VBB150
I am *pretty* dure it had a sidecar at one point.
@subetherbass avatar
Rear suspension (& likely front) along with new tyres will make a world of difference
@greasy125 avatar
@greasy125 avatar
man, I love it. hopefully the paint cleans up underneath all that crud.
I had a P that was sitting for AGES and got it going in the same manner. the seals and clutch ate themselves about two tanks of gas later.
cool little bike!
1968 VBB150
1968 VBB150
Thanks!! Here's an update pic
@fng avatar
1960 Allstate VNA, 1962 VNB
@fng avatar
Looks very good.
@greasy125 avatar
@greasy125 avatar
please for the love of all that is holy, keep that just as it is! taillight and rack and stripes and all!
love love love it.
now just hot rod the motor, EI, and a road pipe or a noise maker! after rubber and shocks of course!
1968 VBB150
1968 VBB150
Not changing a thing. Patina all the way.
@greasy125 avatar
@greasy125 avatar
that's what I'm talking about!
lemme know if you need any used power and speed parts!
Imagine if sellers weren't lazy. A quick wash and wax and look at that beaut!
So durable, the original paint! Clap emoticon
And you got one of the best colours, and you got it looking so damn sharp.
I heard it's like rather fast? I wonder what top end it's got. Still stock 125 or ...
@qascooter avatar
@qascooter avatar
Beautiful! Clap emoticon Clap emoticon Clap emoticon
@qascooter avatar
@qascooter avatar
This always surprises me. And if they can't wash it to sell it, you KNOW they never took care of it in the first place. Or maybe for a minute....
1968 VBB150
1968 VBB150
Took a putt down to Htown and spent a good hour with Kyle, who I had bought some vba stuff from. Love scooter people, so chill. Missed brbs cause he was busy, but next time for sure.
1968 VBB150
1968 VBB150
UPDATE!
Ok. so I got her on the road and running well- there was an issue with the ignition switch not being wired correctly, but I fixed that with a new switch- now blinkers all work ands well as the horn etc. Passed inspected and will get registered while I am back home in CA.
NEXT issue. Once I got it on a "real" road, it is clearly underpowered.
Looks like I am going to need to add a 177 kit- do I need to rejet my 20/20 as well? Its way more underpowered than I had first realized.
Sorry I missed ya on your last visit amigo!
Congrats on the P rocking and rolling Dood!
Yes on the rejet.
Many folks will also suggest going to the 24/24 carb. (I am not one of them.)
Add a 177 of good quality... upjet the main, box exhaust... bobs your uncle.
1968 VBB150
1968 VBB150
Anybody holding a 177 kit thats ready to go (chamferred and all that?) Broken in already? Even better.
Greasy?
Wallets open, I am headed back to TX at the end of the month, so I would like to slap it on then.
@greasy125 avatar
@greasy125 avatar
Greasy?
oh... let me check. I think kajiit used power & speed division might have something on the shelf.
but you gotta buy that ironing board back rest too! Razz emoticon
1968 VBB150
1968 VBB150
Yes i need that as well. Purple rain is nearing completion.
[ Time: 0.0137s ][ Queries: 4 (0.0045s) ][ live ][ 343 ][ ThingOne ]
