Hi,
I did a cursory search on my topic, but I'm struggling to find the right words.
2009 S50, has been sitting untouched for 7 years. A week ago I flushed fuel, new battery and sprayed the hell out of the carb.
Problem: Vespa starts ok. Heater/choke starts it up and it seems to keep going once it calms down. Turning the throttle gives a nice bump in acceleration. It lurches forwards, but then it hits 5mph and bogs down and just feels/sounds starved. Can't get going above a crawl/walking pace.
Specifically I...
1. Replaced fuel and vacuum lines. Sucking on the vacuum and the fuel flows.
2. Sprayed through main and idle jets. Ran a length of copper wire through them.
3. Checked the diaphragm seat/seal and condition.
4. Soaked everything in carb cleaner
5. Done all of the above twice.
I have not:
1. Removed the spark plug (can't access the thing in its tight corner)
2. Cleaned the air filter. Blocking the air intake makes the RPMs climb. Seems ok
3. Adjusted mixture - don't have the tool
4. Replaced any jets/gaskets
5. Checked for a mouse-house in the exhaust (I read about that somewhere). But there is exhaust felt.
Things that I wonder about.
1. The sensor hose that runs to the ECU? It is in pretty bad condition/bad seal. I have read about others removing/blocking this hose. I have left it poorly attached.
2. The needle-slide seems to have a slow response on the way down/closed. When I blow on the vent (? oval-segment above throttle intake) the slide moves up, and then takes a second to slide down. Maybe that's fine? I don't know.
3. I read on another post that the variator (sp?) was a likely problem? I'm nervous to open the case before ruling out anything that might be obvious/easy.
Thanks in advance for any help.
