a question or two about mitts / muffs / whatever they are called.
Do you find that they interfere with the brake lever or accidentally bump the horn?
I normally ride with my hand 2inches out from the handlebar cover with 1/2inch resting on the bar end. I then slide my left hand in one inch when using the indicators or the horn. When I tested while just sitting on the bike (I haven't ridden yet) with some cheap ones I bought, I can hear the brake switch click when I do that slide and then unclick when I return to my normal position. Not sure if they actually engage enough to actually do braking. Hmmm.
So I'm thinking maybe I should buy some short levers ... (I normally 2 finger brake anyway)
Thoughts?
