@nelluch125 avatar
1981 Vespa P200e, 1985 Vespa PX125e, 1985 T5, 1971 Sprint Veloce
@nelluch125 avatar
Hey folks,
Any recommendations on how to remove these two bearings (needle and roller) and the bearing race on the flywheel side?
This comes from a ET3 small frame engine case.
Thanks for your input.
@hjo avatar
@hjo avatar
Scooter Mercato has a bearing extractor set.
https://www.scootermercato.com/Scooter-Parts/Factory-Tools/T-21467
@geeklion avatar
The Dude
The Dude
@geeklion avatar
heat the case up with a propane torch around the bearings. they likely will fall out. Or toss the whole thing in the oven @ 350 for about 20-minutes for same result. That usually works for me, without having to use an extractor
@rallygeek avatar
@rallygeek avatar
If you are using the extractors I find it often works better if you remove the needles from the driveshaft support bearing. There is a little nipple in the casing casing sometimes that stops the extractor getting between the case and bearing.
@der_blechfahrer avatar
I haven't tried it myself, yet, but there's a video of someone stuffing pieces of toast into the needle bearing until it is pushed up out of its seat.
@rallygeek avatar
@rallygeek avatar
Haha I tried that after I broke a puller. It didn't work.
@safis avatar
@safis avatar
For the flywheel, weld a piece of iron bar and then hit it to come out. For the gearbox bearings I weld a bolt and use a slide hammer. I'd replace the flywheel bearing with a NU204…
@dirty30dillon avatar
Yes
Yes
This works 100%. I've used it in multiple situations.
You need cheap bread, and a punch that is very close to the ID of the bearing.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Same - total waste of time
@nelluch125 avatar
@nelluch125 avatar
How long do I apply Heat with torch?
@chandlerman avatar
Innovator
153 Days Since Last Explosion
Innovator
@chandlerman avatar
Until it falls out? Razz emoticon
Seriously, you won't damage the cases with a propane torch. It's not not enough. The cases are a BIG heat sink, though, so it can take some time to get there. Some people use a cheap hot plate for this sort of thing with good results, too.
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
This guys videos are great! He covers large and small frame engine bearing removal in this video. I wish I spoke Italian.
Go to the 9:30 minute mark to see how it is done.
⚠️ Last edited by Hec In Omaha on UTC; edited 1 time
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
if you turn on subtitles, you can then go into options and set it to auto-translate to your language of choice. I usually go with English, but you do you
1980 P125X US Spec
1980 P125X US Spec
Chandlerman
Thanks for the auto translate tip! I just tried it! I never knew it existed! That is awesome!
Hec
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Yeah, I use it all the time. I try to watch the German scooter videos auf Deutsch, but if they get too colloquial, I can't keep up and it's a lifesaver.
It's also gotten a LOT better over the past six months or a year. Machine Learning for the win!
@subetherbass avatar
I'm going with a loaf of bread as well
@nelluch125 avatar
@nelluch125 avatar
You should post a video of this bread technique.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Bread works on the larger bearing. I did it.
See Random Tips and Tricks, page 14.
⚠️ Last edited by SoCalGuy on UTC; edited 1 time
@rallygeek avatar
@rallygeek avatar
this being the bread method:
https://youtu.be/Xe-wm47OAP4
We only have seeded bread so all it manged to do is get the seeds everywhere..
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
@nelluch125 avatar
@nelluch125 avatar
Amazing. Probably takes some time. Hahaha.
Now what about the main bearing race?? What kind of grocery can I used to remove that?
@swiss1939 avatar
@swiss1939 avatar
Must be the cheap loaf!
@nelluch125 avatar
@nelluch125 avatar
I'll try it and let you all know how it goes!
@gickspeed avatar
@gickspeed avatar
someone will surely post something about adding JB Weld to the race and hammer it out.
Rhetoric aside, welding a piece of scrap to the race is the only way to properly do it.
A+, Keep up the good work.
@orwell84 avatar
@orwell84 avatar
That makes sense. It looks like those bearings are in blind holes. A couple MIG spotwelds to attach something to grab onto is a great idea. I used the remove the needles trick with heat to get out the selector box bearing on my 150 case. Heat is really your friend, so don't be shy. Even with a Map torch it would be hard to do any harm. A heat gun works pretty well too.
[ Time: 0.0091s ][ Queries: 4 (0.0024s) ][ live ][ 343 ][ ThingOne ]
