Hello all
Hopefully a simple answered question….
Spaco carb….I assume the spring on the slider should be strong enough to
Pull the slider back to its resting closed/idle position ? Mine currently isn't when connected up to the throttle cable.
I've got a problem when I pull the clutch in when changing up, the revs stay high. Do the same with no throttle (like going downhill) and she idles fine. I'm certain there's no seal gone or air leak because I can do a 40 mile trip problem free. Just had the carb serviced too hoping it was just in need of new gaskets. No changes…this has just developed?
Kevin
