I've been a long time reader, not-so-long poster here, but having finally started to settle into my house after leaving Brooklyn and the insanely expensive 1 car garage I was renting that was 2 miles from my apartment, I have started to put together my plan for the 1976 50R I picked up close to 2 years ago, from a friend in Atlanta.
I had been looking for a small frame project in New England, but as I am sure many of you know the NYC Metro area commands a huge price tag on vintage motor-anything.
Either way: enough back story. My plan for this bike is to build this slightly thrashed bike into an all-occasions rider. I want something with enough grunt to handle rural Connecticut roads without feeling too burdensome (I have a garage full of mopeds for that purpose) but is also small enough that I can load it onto the rack on my SUV and bring it to NYC and enjoy there while I work.
I'm going to start solely with my plans for the motor, and hopefully everyone can weigh in, and correct any issues you might see. I have built a number of Vespa mopeds, and motorcycles, but as it usually goes my experience with smallframes is light.
1) I am going with a new roller 51mm crank in order to run the larger cylinders. I may be able to eek the same power from the shorter stroke, but I have enough 10k revving mopeds and would like to make this torquey over peak power. I would prefer to stay 19/20 so that way I can keep the stock points for now. I know, POINTS. But I find points to be incredibly durable and field-serviceable. Should budget allow, I could see myself going with a simple static CDI system in the future.
2) My plan was to mate this to the 57mm DR Cast Iron kit. I've used DR's on my Vespa Mopeds and enjoyed them, and have heard that the DR is a milder cylinder. And I COMPLETELY open to other suggestions. My experience in moped cylinders also extends to just about every other major brand, so please: tell me your thoughts.
3) My plan was to remain as a 3 speed, as I enjoy my Lambretta's 3 speed gearing and ride style. Mostly though, this is to save some money as I know gearsets are something that shouldn't really be nickle-and-dimed. Along these lines, I need to consider what primary gears I would need. I am hoping for a sustainable 50-55 on the flats, with a standard sized rider.
4) As I am hoping for plenty of torque, I realize the clutch will need addressing. I have no clue where to start on this, except I see alot of information regarding swapping to a PK style clutch. I am happy to get some links to pertinent information, but if there is a modded stock EQ or drop-in solution that will work for my plans, I am all ears.
5) For pipe and carb, I have a spare PHBL 25, PWK28 and a handful of PHBG and Mikuni, but I wouldn't mind using the PHBL to keep the carburation Italian. For pipe, I was looking at the EGIG Banana, but am happy to consider a traditional cone pipe that won't break the bank.
Once I can start putting together the parts list I need to get the motor squared away, I will start looking at freshening the brakes and suspension to match, and then finally get the seat recovered and some fresh cables installed.
Looking forward to any advice and help, as well as getting further into the build process.
