@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Hey everyone. Dead batteries happen (especially for those with mid-2000s Vespas). Knowing how to jumpstart your Vespa, motorcycle, or really any other 12v vehicle is good knowledge to have.
In Canada especially, where everyone drives around with jumper cables in their car because winter climates can be so rough on people's batteries, it's not hard to flag a stranger and ask them if they can give you a jump.
It's pretty straight forward, there are basically just 3 mistakes you want to avoid:
- Not connecting the jumper cables correctly
- Touching frame with jumper cables (more of an issue for motorcycles)
- Turning the car (or truck) on (and leaving it on for extended period of time)
Anyway, hope someone will find this helpful and it will help someone avoid paying for a tow.
PS: On this Triumph Bonneville I clamp to a nut that isn't too visible just in case the jumpers leave some scratches, I suggest you guys look for a similar spot on your Vespas, perhaps where the rear shock mounts. I'm sure if we took the underseat bucket out we could find some piece of raw metal, like a motor or something
If anyone who's jumped a Vespa can chime in with where they clamped to that would be useful and I can add it to this post. TY
And yes, terrible pic of me, just took a still frame from the video lol
@bob_cowley avatar
GTS250, P200E
@bob_cowley avatar
GTS250, P200E
I recently had my Vespa battery go to 8.4 volts after it was charged with an automatic charger. The charge current tapered off in the normal manner as shown on the built-in ammeter. Obviously it was an internal battery problem. Jumpstarting did not work as the starter would still not turn over the engine. When I replaced the battery everything was good.
Cheers,
Bob
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Makes sense. 11.3 volts is essentially considered 10% battery capacity and useless, so 8 volts is basically just a paperweight.
Was it the charger that failed or the battery itself? What was the brand?
@lars_danner avatar
2014 GTV300; 2009 S50
@lars_danner avatar
You probably didn't have a good connection between your cables and the batteries. A working motorcycle will ALWAYS start with cables properly attached to a good battery in a running car.
Cheers,
Bob
Please don't have the car running - there's normally no need. A car battery will have an order of magnitude more CCA than any motorcycle can require. However, if jumping from another motorcycle you can start that running (after the cables have been connected) as it otherwise might not quite have the oomph required.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
I've seen batteries get so dead that they are essentially just bricks, and even a booster pack can't do anything for it. If it was in the high 11s, low 12s, you're right, better connection could have helped... but he said it was at 8 volts. That's essentially a shiny rock, and not the expensive kind lol
For reference:
From: Dead Motorcycle Battery: Recharge It Or Replace It? https://youmotorcycle.com/dead-motorcycle-battery.html
@lars_danner avatar
@lars_danner avatar
For reference:
That wasn't my point. Sure the battery might need to be replaced, but with properly attached jumper cables, the bike WILL still start and run even with a completely dead battery--it just won't take a charge.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
I know it wasn't your point. I'm saying my experience is different from yours, and trying to show you why that's the case
Usually, yes, but if the charging system is open circuit and the scooter battery is already discharged, it won't stay running once the jump connections have been removed.
A dead battery isn't always just an old or neglected one, it can be all down to other electrical problems. E.G. an MP3 500 that's stalled or won't start because its 'hidden fuse' has disintegrated can often be diagnosed as a bad battery when that's simply not the case.
@bob_cowley avatar
GTS250, P200E
@bob_cowley avatar
GTS250, P200E
The charger is good. The failed battery was a two year old Canadian Tire brand. I should have measured the voltage when the batteries were connected together. With the bad battery, there was not as much as a click when I tried to crank the engine. With the bad battery and the battery giving the boost, the lights came on very weakly and the starter solenoid clicked but the engine would not turn over. With a new battery, everything has been fine for several weeks.
Cheers,
Bob
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Hey Bob, just realized you're down the 401 from me. Feel free to shoot me a DM if you ever run into any trouble with the Vespa
@bob_cowley avatar
GTS250, P200E
@bob_cowley avatar
GTS250, P200E
Thanks, Adrian.
Cheers,
Bob
@harbinger avatar
@harbinger avatar
Just realized you're from TO. What part? I'm downtown in the King St West neighbourhood.
As far as batteries go I've never had an issue with any of my Vespas or BMWs. Now Ural on the other hand let's just say I carry a Canadian Tire 12v charger and long extension cable with bar at all times.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
I used to bartend in Parkdale for 6 years, and worked for a summer at some pools around King and Bathurst. I'm living up at Dufferin and Eglinton now though. I'm fairly certain we must have met at some point, you look very familiar in your profile pic
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
I have the same experience. My father in law's car was dead. No dashboard lights, nothing. The car had been standing for more than a year due to him having a health problem.
So I connected starting cables from my car's battery to his with my engine running.
Waited for a few minutes to let his battery charge. But no result. The dasboard lights came on but as soon as I tried to start all black. Repeated this, waiting longer, but no result.
It needed a new battery. Apparantly the old one was too far gone.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
And that's only one year of sitting!
[ Time: 0.0125s ][ Queries: 3 (0.0055s) ][ live ][ 343 ][ ThingOne ]
