Vespa Elettrica, GTS 300 HPE
All this while, I've been checking my oil level by:
a) unscrewing and removing the dipstick
b) wiping it clean
c) **reinserting the dipstick all the way (screwing it back in fully)**
d) removing it and noting the oil level.
I recently looked at a motorcycle manual, where the instructions explicitly stated not to screw the dipstick back in before measuring.
It made me wonder if I'd been doing it wrong with my Vespa, unintentionally overmeasuring the oil level. I looked at the Vepsa manual, but it is silent on this issue.
So ... what's the correct technique on the HPE?
@alan4christ avatar
2022 Vespa GTS
@alan4christ avatar
2022 Vespa GTS
You are doing it correctly. It is in my GTS owners manual to check your oil by screwing the dipstick in all the way.
@amateriat avatar
@amateriat avatar
shc: Yep, you're doing it correctly.
Just as an FYI, there is a less-tedious way of keeping tabs on oil level on GTS HPE's, although it does involve changing the oil pan. (Identical to the original, but with a sight-glass installed.)
New oil pan: The better to view your oil level, m'dear.
Installed: A quick glance is all it takes.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
How much oil should be visible in the sight glass for a normal level? It's this being checked with the GTS on the centerstand?
still shopping
still shopping
According to the "robot" youtube half full in the window on the center stand.
My Japanese bikes want the dip stick not screwed in, but my old Ducati and 2020 MotoGuzzi V7 R wants the dipstick screwed in to check. Maybe it's an Italian thing?
@strawberrysoda avatar
2022 GTS 300 SuperTech
According to ScooterWest, a half full sight glass on the center stand equals the max line on the dipstick. If you don't see any oil in the sight glass, you're about 250ml low on oil and should top off.
Check out 25:46 in Robot's video:
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Thank you! I somehow missed Robot's video on the oilpan
Thanks!
@fudmucker avatar
@fudmucker avatar
If a "half full" sightglass = MAX oil level (per the above post) I would recommend that the user consider painting a dot in the centre of the glass to give you a consistent reference mark. (My BMW had similar sight glasses with a reference dot.)
I would suggest the maker/sellers consider this reference mark.
I carry a 200ml bottle of engine oil in a ziplock bag in my cubby.
I also carry a 200ml bottle of undiluted antifreeze in case I must top up the radiator en route (or help out a fellow Vespa rider in the same situation.)
I would still use the dipstick to check my oil level when topping off so, for me, the sight glass would mainly be used as an indicator of when to top off and not as an exact oil measurement. My guess would be that that's why there's no max/min marks on the sight glass.
To your point, though, putting a simple dot on the sight glass with a sharpie could definitely be helpful.
PX 150 and GTS 300 HPE Super Tech
I installed the sight glass oil pan on my 2020 HPE and when the scooter is on the centerstand and the oil level is at the halfway point in the sight glass, my dipstick reading is exactly at the full mark. It does take a few minutes for the oil level in the sight glass to settle. If you check it shortly after running the engine and then immediately add oil to bring it up to the halfway point in the sight glass, you will end up overfilling it. Don't ask me how I know. Facepalm emoticon It is also important for the scooter to be on level ground when it is on the centerstand, but that also goes for using the dipstick.
@bobbyoakes avatar
Vespa GTS300 SuperTech (iScoot); Vespa GTS250ie
@bobbyoakes avatar
Not to hijack this thread, but it is related...
I have a 2021 GTS 300 SuperTech, 6 months old, 5000 miles. When it was delivered from the dealer, my mechanic found it was 120ml low. I drove it a little and had its 600 mile service on time. in the intervening miles, I have had to add another half of a liter... 100 & 200 ml at a time. It seems to be getting better, but I'm looking for feedback from other HPE owners about their oil consumption.
BTW, the dipstick all the way in vs. "just the tip" works out either way. If the tip gets wet, then it will be into the hashes if you screw it all the way down.
As a side note, and why it is related to this thread... Piaggio moved the dipstick to the other side of the engine from previous models, and it is at ROYAL PAIN IN THE A$$ to check. Not only is it harder to reach, you have to do hand-limbo to get the stick out of the engine area to read it, plus, re-inserting it is akin to playing "Operation" where it has to follow a very narrow path to get in the right spot. If not, you can easily break the stick off and it falls into the motor/waterpump. Its such a problem that the water pump gaskets are on back order.
In conclusion, (1)it's difficult to check the level and (2) it's using oil much faster than previous models. Double whammy!
2019 GTS 300 HPE w Malossi
Yes HPEs drink oil. There's been plenty of threads about this.
I prefer to have the dipsticks as far away from me and my scooter as I can possibly get them.
@amateriat avatar
@amateriat avatar
Hence the existence of an aftermarket oil pan with that lovely sight glass: Robot mentions the relocated oil cap/dipstick "issue" with the HPE.
According to what I've heard, later-model GTS HPEs' oil consumption should noticeably decrease somewhere between 1000-2000 miles; I've only clocked 819 miles on Thelonica so far, and I'm just a bit over 200 miles since her first service, so I'll see how things shake out over the next month or two.
I have other words to describe them, but: Roger that.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
I concur. But I don't know abut the electric Vespa.
@garthhh avatar
@garthhh avatar
Check when the motor is cold, say before the ride & just unscrew & look
No need to wipe & re-insert, that's just an extra step
This, exactly.
@alan4christ avatar
2022 Vespa GTS
@alan4christ avatar
2022 Vespa GTS
My 2022 GTS doesn't seem to use oil. Maybe Vespa has solved the problem. I will continue to check the level often. I have 850 miles but have been taking it kind of easy on her. The highest speed I have gone is an indicated 75 mph even that wasn't for long.
I'm not sure how it is on the non-HPE Vespas, but taking the dipstick out of my GTS 300 HPE is like playing Operation — if you don't take it out at just the right angle, then the oil on the dipstick gets smeared and it's difficult to get an accurate reading.
@themayor avatar
GTS 300 (2021)
@themayor avatar
GTS 300 (2021)
My 2021 300 oil hasn't needed any topping off. Serviced per the schedule. Just about to hit 2k miles.
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
It depends much on your riding style. WOT on the highway will consume more oil, taking it easy, less.
@rottekatz avatar
Primavera 150
@rottekatz avatar
Primavera 150
Just tried that and there was oil to the top of the hash marks.
Wiped it off and screwed it back in. When I took it back out it showed half way up. Last rode yesterday.
@themayor avatar
GTS 300 (2021)
@themayor avatar
GTS 300 (2021)
I've considered getting a different color dipstick - seems like it'd at least be easier to read.
@bobbyoakes avatar
@bobbyoakes avatar
I'm approaching 6000 miles, and the oil consumption has improved, but not enough that I can leave my spare liter of oil behind.
In all fairness, I think there is a longer ride-in interval on the HPE, and mine is getting increasingly better performance each week. Fuel mileage is creeping in the right direction, power at the top end is getting better too.
I've done 30,000km and still topping up now and then. Note: I am not saying if its similar or less than how much I'd top it up when new ... haven't get adequate records to answer that theory.
[ Time: 0.0110s ][ Queries: 4 (0.0026s) ][ live ][ 343 ][ ThingOne ]
