Im slowly testing my 300 due to an inconsistant idle. My gut feeling there is something wrong. Today i decided to test the the voltage during idle since i noticed it cuts out as soon as i twist the throttle. When i hold the throttle steady steady at 2200 rpms it will surge to 3000 rpm for half a second and go back to 2200 for ever 7 seconds or so. It will do that over and over. The other thing i noticed when i start to twist the throttle slowly the rpms increase like usual but then rpms cut out while im still holding the throttle in place.
The voltage im seeing during idle (~1680 rpms) is anywhere from 12.2v - 13v. (Voltage jumps around a lot)
At 3000 rpms its somewhat steady at 14.5v.
I now have 3,300 miles on my '18 Gts300
Is this a Stator ussue?
