Here you go!
https://www.scooterwest.com/malossi-cylinder-kit-gts-gtv-hpe-75-5mm-282cc.html
2019 GTS 300 HPE w Malossi
Posts: 9128 Location: Batmania aka Melbourne, Aus |
Can't help but thinking the polini 294 would be better than the Malossi 282
Polini cylinder 294cc for Vespa GTS 300 |
Can I ask the question Why! What is wrong with the stock setup what are you looking to gain?
Outsider wrote: Can I ask the question Why! What is wrong with the stock setup what are you looking to gain? ⚠️ Last edited by Lars_Danner on UTC; edited 1 time
steelbytes wrote: Can't help but thinking the polini 294 would be better than the Malossi 282 Polini cylinder 294cc for Vespa GTS 300 |
Lars_Danner wrote: True but I don't believe that is available yet for the HPE. |
Posts: 11801 Location: Hermit Kingdom |
Outsider wrote: Can I ask the question Why! What is wrong with the stock setup what are you looking to gain? |
steelbytes wrote: Really? Half the members of this forum want more power |
johnnytwowheels wrote: Good luck with your installation! Let us know how it works out. |
Posts: 4141 Location: Kingdom of Lanna |
Does anyone know what a "HTR" ring (High Turbulence Ring) is? Is there a picture of one?
Otherwise, it is meaningless marketing waffle. |
Lars_Danner wrote: Honestly not worth it for a 4cc displacement increase. |
Posts: 1624 Location: Tucson, AZ |
Power and torque talks... displacement is secondary. What power/torque is each kit is making? displacement in theory suppose to help with torque but it is all in the metallurgic/materials, weight of the components(piston/rod), angles, openings, timing, compression ratio, cooling of the head, shape of the head, piston rings, piston shape(design in general).
Both brands are incredibly so it is a win-win already. |
steelbytes wrote: It also has a higher compression than OEM. |
waspmike wrote: So they could simply sell a high compression piston? |
Outsider wrote: Can I ask the question Why! What is wrong with the stock setup what are you looking to gain? 2020 HPE Oil Consumption or Lack Of (Page 2) |
